What are some of the nicer radius/angle dressers?
eKretz
Diamond; Mod Squad
Mar 27, 2005
Northwest Indiana, USA
Looking to acquire a radius/angle dresser for my grinder, not real familiar with what is out there so I figured I'd run the question by some of the old grinding hands here. What are some of the better ones you've used, and what feature or features make them nicer to use?
My grinder is a Brown and Sharpe Micromaster Series 2, 8"×18" travels. I've got a Grind-All that can do radius dressing with an accessory, but don't have that accessory. Could be easily made I suppose. Anyone tried radius dressing with a Grind-All? How was that?
We make the The Clearview© Radi-Angle Form Dresser. Not the cheapest but it is all made in house here. We also do all the repairs and reworks.
I like the way the J&S Fluidmotion works, but have to totally dismount the wheel guard (not just open it up) on my current SG to use it. So I've gone over to the type that rotates around a horizontal axis instead of a vertical axis.
I always wondered why the wheel guard on my grinder was mounted on a plain round diameter so it could be rotated - that is probably exactly why.
Anybody know of a video that shows the J&S in action? Can't seem to find one on Youtube. I was aware of the Last Word, having seen it on Suburban Tool videos. I'll have a look at the others, thanks.
Good point the J&S dresses at horizontal center line... and the last word type at the bottom. Each has its advantages.
I've always preferred the Herman Schmidt/Kuhn dresser for radii. Low profile, easy/accurate to set, and you can watch through the center axis for alignment. Angle can be set with a sine bar. Not as good for complex/multiple form dressing but I've seldom needed that in one dress. Seems to be preferred by most die makers in Chicago too during the 80's/90's. Guess it depends on what you want it to do like any other tool.
Buck, after thinking about it I now actually wonder that I can even use that vertical style dresser without a table lock. Near as I can tell the machine doesn't have one unless I'm just totally missing it somehow.
I think the last word type is most practical, but even that needs a table stop. you just set your stop and travel your long travel to it, so stopping in the go direction. Your cross dial number noted at the front wheel face touch or the rear wheel face touch. often you skim dress the face that intersects the radius, or not if not a fussy job.
Not a bad idea to have a drop in parallel to drop before your stop so you done need to find that same place, at wheel long way wheel center. your cross place good to note on your pad.
The last word type you set a position above or below the center gage post for concave or convex. and the feed to dress is the down feed, very easy to use. the J&S you can micrometer over using your second class micrometers.
So nice about a TC grinder is the you have a fine adjusting long travel stop... Not a bad idea to fab one for a surface grinder, just a drop in block with a screw that would bump your stop post and stop.
And you just hit why the under style is better.
No matter the side feed fine adjust stops SGs do best at up/down and in/out.
On either centering the diamond point on the wheel center-line and staying there is a must. if picky about angles and rad shape and checking at 100x .010 off on a 6 inch wheel is a problem.
The best are the mounts on the spindle itself but these expensive and now rare.
I tossed five of these in the dumpster since they do not work on diamond wheels but came on Micromasters I bought, ....wish I had saved one. This that kick yourself forever type thing.
Later I would learn that you can form a diamond wheel with a molly stick in place of a dressing diamond using such for touch up.:wall:
The process is just a swing to two fixed sides. The diamond point has to be in the right location to the swing pivot (IE the radius you want.)
Confusing at first but no different than swing grinding a radius on a tool end.
Bob
I also have a Tracaform dresser, with that you make a template then with following a tracer bar to that template you dress the wheel. Good for grinding a form on the part. I Cant find one on the internet to show what it looks like,
This like an Engis diaform, sort of a pantograph type deal?. One to one direct or multiplied/scaled on the master form?
Bob
