Wheel adapters/ HUB for Covel surface grinder 10-1238
Results 1 to 9 of 9
    Apr 2017
    Arkansas
    49
    10
    Default Wheel adapters/ HUB for Covel surface grinder 10-1238
    My hub has a lot of ware on it and looking for a new one with the balencing hub.
    it has a 1-1/4" Arbor LH thread. looks like it can take up to a 3/4" thick Stone type 1,
    the old Hub i have does not have the balancing lugs like the newer ones.
    and trying to find a Manuel for it. Covel surface grinder 10-1238 even one close to it will help.
    if anyone can help thank you looking for what type of Hubs / adapters i can use on it.
    any help on this is greatly appreciated.
    Apr 2017
    Arkansas
    49
    10
    has anyone seen anything like this for a Surface Grinder?
    https://oneway.ca/pdf/Balance%20Kit%...Dec%202010.pdf
    Jan 2013
    Plainfield, Indiana, USA
    1,857
    1441
    991
    New wheel adapters come from William Sopco and sons . . . google it.
    Wheels of the size you are looking at only need balanced for the most exacting work. If you want to balance a wheel, first install the wheel securely on a hub that is equipped with the balancing weights, then DRESS the wheel, bottom and, less important, sides. Remove hub with mounted wheel from grinder spindle, and NOW you can balance the wheel like your posted video shows, or with another method, but you must dress the wheel first
  4. Likes CRJarvis, machinistrrt, digger doug liked this post
    Apr 2017
    Arkansas
    49
    10
    thank you. i have been reading everything i can to old manuals and lots of videos. this will help a lot http://www.wmsopko.com/sopko_04_to_30_53.htm Thank you.
    have been working on getting the Hub off. the hub puller is Right hand thread anyone know what type of thread it is?
    Apr 2017
    Arkansas
    49
    10
    thanks for this wmsopko.com info it has helped me out, thank you thank you. tried to reply to this before but have to wait for admin to approve.
    Apr 2017
    Arkansas
    49
    10
    just busted the belt on it last night anyone have ideas on how to install it. i looking at trying not to take it all apart to do it.
    picked up a belt that will work will post info and photos as i get them. anyone have a manual for this one or one close to it?
    Apr 2017
    Arkansas
    49
    10
    20210914_164558.jpg busted it had not used it in a wile and after a few passes it went. so stopped by a few bearing places in town and found this. 20210914_155700.jpgthe PowerGrip 450H100 was just right. cut it and a hell of a job threading it in with out taking the top off. cleaned it up some wile i was at it.
  9. #8
    Mar 2005
    Indiana
    6,539
    2349
    2538
    I take it the belt is for longitudinal table travel? I said a few choice words when reinstalling the one on my MicroMaster for the first time that serves the same function. They definitely have some tricky spots.
  10. Likes CRJarvis liked this post
  11. #9
    Apr 2017
    Arkansas
    49
    10
    it was a job to do with out taking off the table.
