Wiring a Harig spinde motor for 220V?
Results 1 to 3 of 3
    Jan 2018
    South Carolina
    127
    46
    Default Wiring a Harig spinde motor for 220V?
    I have an old Harig 6X12 that I know little about. One thing I don't know is whether it is wired for 220V or 440V. There's a sticker that should say, but it's partially torn away, including the part I need. Anyone have a chart of the wiring pairs for each voltage? I assume it's like most 3ph motors where you change the pairings and hook-up for high voltage or low voltage. I've been search the interwebs, but coming up empty. It's a Doerr motor, if that helps.
  2. Likes TDegenhart liked this post
  3. #2
    Mar 2011
    Geneva Illinois USA
    4,892
    1918
    1822
    Another item that needs to be addressed is the oil pump at the rear base of the column. You should find what you need for the main motor here.
    electric motor connect - Google Search
    Tom
    Jan 2018
    South Carolina
    127
    46
    Thanks- I didn't know if was an industry standard, or if each manufacturer has their own wiring schematic. I'll have to see if the oil pump even works, and what the voltage is on it. It's plugged into a box that's mounted on a transformer, but there's no labeling whatsoever on the transformer. IIRC, those pumps are rather expensive- probably more than I paid for the machine. For my casual home shop usage, there's probably a low-buck workaround, even if it's just a manual oiler.
