3d metal printng
cob
May 29, 2009
San Francisco
Hello everyone so I have been reading
on 3d metal printing for a while, my question is
does this look like its the next big thing in manufacturing or just a nitch
Jet engine manufacturers are really exploring the tech. The ability to print with encased nozzles and voids is huge to that industry.
3d metal printing, especially sintering machines, circumvent so many manufacturing expenses and hurdles that it can only take off. Just think of how many machines, tools, and employees you need to manufacture something like an impeller, for instance. Additive machines also waste no materials, unlike Lathes, Mills, 4-axis CNC machines, etc. The complexity and intricacy of parts they can produce is unachievable on traditional machines. I've seen a DMLS machine produce every component of a turbocharger. Traditional methods would entail a forge, casting molds, 4-axis CNC, lathe, balancing machines, etc. That doesn't even include the salaries of the people to run those machines and the material expenses. It's pretty amazing stuff. Right now the primary limitation of these machines is their speed; most find their place in prototyping. I believe they start around 300k and the quicker machines are 1MM+. Not a huge threat to traditional manufacturing right now, but all the money in the industry is being funneled into fixing that. Every few years I check in on the cost and it's always falling.
there are different approaches to metal printing, i.e. diff tech. The prices are still fairly high as is final product of varying degree of properties. No question that some things beg for it and will be viable, but for now I'd think it's still a niche in a niche market. Just getting a machine and hoping that it would be useful for something to make money without doing research on cost/benefit it a tought call.
I'd say it's too early now unless you got specific jobs and money lined up. Thankfully the rest of the tech like modeling, scanning is well established.
I'll make a brash statement to spark this conversation:
3D printing technology will replace ALL but the simplest of metal milling (and those operator's jobs) in the next 10 years.
Can anyone reassure me to the contrary? (Here's hoping someone can).
(Here's how inexpensive the machines are getting):
2019 Metal 3D Printer Buyer's Guide | All3DP
It doesn't matter how inexpensive the machines are getting so much as how expensive is each part to print. Currently, stuff like exotic alloys, small runs, new designs that reduce part/assembly components are where metal printing shines.
I don't foresee 3D printing of simpler widgets 10 years from now being less expensive than milling them, but I've been wrong before.
Plus, even if you 3d printed a mold so it could have some rad cooling channels not available otherwise, you would still mill and then polish the mold.
I don't think so and here's why.
3D printing is slow. While it's perfect for prototypes, casting and machining are faster. Injection molding (plastics) and die casting (metals) are much faster for volume parts and machining is still the fastest way to add fine details post-casting. A while ago I read an article about how the Navy was 3D printing prototype titanium ducts to add rebreather capability to its deep dive helmets. The article mentioned that production quantities would be made by conventional methods.
Often small batches of simple parts can be done via CNC in the time it would take to print one or two pieces. The more solid the part (few internal passages) the less attractive printing is.
3D metal printers are expensive and most are not built for the durability needed to crank out production quantities year after year.
While 3D printing is technology that will see increased use for complicated parts with many internal details I don't see it as replacing other methods for many commonly made parts, certainly not in a 10 year time frame.
Let's also not forget stamping and forging from which millions of common parts are produced every year. As I type this I'm looking at my desk stapler, which was built with a mix of injection molding, die casting, and stamping. I can't see a 3D printed version as economically viable to produce in the quantities sold each year.
As others have said I think there are niche areas where 3D printing in metal is going to replace all other techniques, but there is no way it's going to displace all machining unless there is a quantum leap in the technology itself. For instance:
Manufacture of rocket engines:
Rocket engines have a lot of complex plumbing and were traditionally produced in many separate pieces and then stitched together using various welding techniques along with pipe joints and so on. This results in the labor cost for assembling the engine being very high, as well as machining cost being very high due to the complex nature of the parts. 3D printing is starting to drastically cut into the expense of manufacturing rocket engines because things like regenerative cooling channels can simply be printed as part of the rocket nozzle as opposed to having to make them in some other complex and time consuming way... The engines that Rocket Lab uses on the Electron rockets are almost entirely printed, and each engine apparently only takes 24 hours to produce...
Manufacture of Bolts:
On the other hand there is just no way that a 3D printer is going to compete with a screw machine for making things like fasteners in the next 10 years. A screw machine will make a fastener or pipe fitting every few seconds! Making them on a 3D printer is just not economical in comparison because they are simply too slow.
obviously until any technology is cost competitive it wont become common
when spray metal torches came out they said it would become common to spray metal to shape. $30/lb just for spray powder plus the fuel, oxygen and labor cost it never became common for low carbon steel parts.
alot of new technology parts cost $1000. for even small parts
I just priced a small bracket printed in titanium and the cost was between $1000 and $1500, Then it would have to be heat treated and post processed. I can machine the part for counting machine time and material for around $300 and ready to use when I am done. 3D metal printing (DMLS) is great for parts that can not be made by traditional machining practices. It's here to stay, but it will have to improve in finish and cost before it starts cutting into the normally cnc parts business.
Tom
Metal AM is definitely going to revolutionize the high value and job shop type manufacturing environments such as aerospace and oil and gas industries. Mainly due to huge material waste reduction, ability to manufacture complex geometries and consolidate parts and ability to manufacture parts directly from digital formats that have been mathematically optimized. On the other hand, currently, the main barriers to full adoption of this technology as a means for manufacturing end-use parts is the lack of experience using such processes and system to fully understand the effect all the various variables and parameters have on part quality, lack of historical data proving metal AM part performance when compared to traditional processes, lack of industry standards and in turn, the high cost of setting up a metal AM production line, but more importantly qualification and certification of such a production line.
Another important thing to keep in mind is that metal AM is driving a design revolution in the aerospace industry. Never before have designers had as much freedom, which is only now a possibility due to metal AM's ability to print such unique and complex parts. When such designs start to become a reality (traditionally such revolutionary designs in aerospace take decades to become accepted) in the industry I foresee huge growth in metal AM process acceptance.
I think I can speak on this matter with some expertise.
It will never replace the majority of traditional manufacturing methods, hands down.
"those operators" will simply need to learn some new skills. If one can text and drive, they can learn to import an SLS file.
Position part in the build volume, duplicate and nest parts. Load material, clean nozzles, swap build plates and send a GIF
to their friends.
It will most certainly become more commonplace and fall in line with the rest of the tools of industry.
The prices for the quality machine/process will only slightly decrease. The quality and throughput will be increase to the
point it is a worthy investment. Replace much but not all. Even the best AM quality;
Part details requiring high tolerance and finish will still need machine tooling.
Ex: It is hard to beat the physical properties on a high alloy steel that has been smashed and squeezed with tons of pressure
at high temperature. Subtractive machining will still be needed as will skilled programer/operators.
Ex: From print to shoebox full. A length of rod in a swissturn style lathe can be make into 10mm short socket sized parts with,
internal/external threads, cross holes, flats/hex in 12 hours on a bad day.
You will know it has made it like the 'Cover of Rolling Stone' is when it is a chapter in Machinery's Handbook.
