marryjutta
- Jul 6, 2020
The file extension DWG is a unique form of AutoCAD drawing database file, which has the capacity to store both forms of data. The design data and also the meta data are its content. You would also find out that this extension has databases related to AutoCAD, such as 2d or 3d drawings, which best describes the AutoCAD designs.
One of the features of DWG extension is its vector format, and it stores data accordingly. The format can be opened on both Windows and Mac operating systems. DWG is more compatible with Windows operating system.
You can use DWG format with a number of applications, such as core paint shop, or CAD soft tools. It is also used in Adobe Illustrator, and the usage with Adobe Illustrator shows the AutoCAD designs elaborately. The use of the extension on Windows operating system also spreads to Graph soft, and Autodesk AutoCAD.
With Mac OS, the use of file application spreads to engineered software PowerCADD, and also adobe Illustrator and Graphisoft.
The file extension PUB is the creation of Microsoft Office, and therefore, it is related to publishing. The extension helps you to create and share a lot of publishing stuff.
PUB stands for a document and can have vector images and texts. The extension is generally used in marketing or promotional documents, such as catalogs related to a product, or even brochures related to company's product. Companies use PUB extension to propagate and even to advertise their products. The posters that you see in the large companies hoardings are created and shared with PUB extension. Therefore, this extension is a common form of file formats used for marketing purpose. The file extension is used with both Mac operating system and Windows OS.
