Large Metal Additive with Weld Wire
Results 1 to 11 of 11
    Nov 2011
    Missouri, USA
    2,140
    1364
    2737
    Lightbulb Large Metal Additive with Weld Wire
    No, I'm not talking about the dumb shapes and little animals we've probably all mud-dobbered together on the weld table when we're bored.
    But I've been researching more and more about Wire Arc Additive Manufacturing technology. The state of things seems to be pretty decent. The technical aspects all make sense. The material quality, with a good power supply and good "CAM" planning all appear, according to the tests I see, as-good or better than wrought metals.
    So what I'm wondering is... for people who end up with low volume castings and forgings... are we going to start seeing "WAAM" near-net shapes to finish-machine rather than forgings and castings?
    I know it'd sure take a hell of a load off the spindle time required to take a 2 ton block of 6061 down to 40 lbs, if it came in near-net at 50 lbs.
    The lead time on some of these low volume castings we end up sourcing for our customers can be atrocious. If we can "print" a part per day, even, it seems like turnaround time would be pretty greatly improved. As always, everyone wants everything yesterday...
    Has anyone else been aware of this type of thing?
    I was at Fabtech last year, and Lincoln/Baker and Fanuc were certainly showing it off.
    I'm curious how much sense it makes to bring in-house, or even to outsource to Lincoln, since they offer it as a service. Anyone out there have experience with it, or considering it?
    Aug 2009
    Oakland, CA
    380
    179
    I haven't looked at that specific DED process but based on this it doesn't look like many companies are considering it viable for aluminum What Metals Can You Print? | Digital Alloys There seems to be much more focus on Ti and Ni alloys where the material is expensive and hard to machine. Big hunks of aluminum are pretty cheap.
    Have you looked at printers for low volume printing sand casting cores like ExOne? ExOne | Sand 3D Printers – Sand Printing & Casting
    Jan 2020
    Connecticut
    36
    31
    11
    The aerospace industry has been doing something similar with LASER and a wire or powder feeder for overhaul and repair for the past ~20 years or so. It is often cheaper to repair and re-machine a worn out part and add that to the existing paperwork than it is to get a new part.
    Nov 2011
    Missouri, USA
    2,140
    1364
    2737
    Yea, imo, the powder stuff is pretty settled and being used anywhere it makes sense. It's very expensive for metals and the machines even more so. We have some products we've designed for use in our automated tooling, that we 3d print. Those are, iirc, a nylon powder, sintered, so not as resource intensive.
    I definitely think if one were to look at purely saving the # of pounds of material to buy, it lends itself more to being used for the exotic stainlesses, tool steels, invars, and inconels of the world. Like TKassoc says, it's tough to care about 6061 or something, if it's so cheap, and you've already got good tools that rip the stuff out so fast. But some of those old aluminum bond jigs and such, if they weren't cheap aluminum I could definitely see wanting to crunch numbers on having a different way. I don't know.
    Just checking some 316 SS type wire stock, Grainger sells 30 pound spools for about $11/lb. Quick quote online with a large stock plate on Alro puts it around $3/lb.
    So if I was able to get someone to print a part out of 1/4 of the material, I'm already dollars ahead on material cost (obv their cost to print and deliver it is something additional) and I haven't begun thinking of the spindle time saved hogging out stainless steel. I don't know how some of your jobs are, but milling away 75% of the mass of a stock piece is not unusual in my experience. Turning 75% into chips might even be very low for some jobs.
    That's just the first material I checked. Maybe I'll have to marinate on this one.
    Jul 2007
    UNITED KINGDOM
    5,266
    3178
    2677
    The pole endcaps on the rotors of the Dinorwig pumped storage scheme generators were partiall made with wire deposition and separate alloying element addition in 1982. It was one of my jobs as a student to take the CEGB inspectors around the fab shop when it was being done.
  6. Likes JNieman liked this post
    Nov 2011
    Missouri, USA
    2,140
    1364
    2737
    Quote Originally Posted by Mark Rand View Post
    That is super interesting. Sounds like a pretty cool student gig. Bet you got to learn a good bit seeing one of the extremes of power engineering in action.
    I think the addition of alloying metals selectively is a promising concept. Stamping, forming, press dies... all out of cheap low carbon steel, then capped off with equivalent wire to S7, D2, whatever, before finish machine and polishing.
    I've never worked with some of those giant molds they use for wind gen
    Oct 2017
    976
    285
    295
    Quote Originally Posted by JNieman View Post
    I have a hard time imagining that the wire feed printers will deposit material faster than a mill can remove it, and en equally hard time imagining that the machines will cost less per hour than a mill.
  9. #8
    Nov 2011
    Missouri, USA
    2,140
    1364
    2737
    Quote Originally Posted by Strostkovy View Post
    I don't think it's helpful to compare the mill MMR to the deposition rate of a printer. Print speeds look like 10kg/hr and higher (only), so obviously, that's not a metric.
    But they aren't the same thing. So it's not a comparison worth making. The time saved in roughing is just one variable in the mix here.
    What I'm looking at is lead times and costs for castings/forgings vs having them made near-net via a WAAM process, and then making sure any other secondary benefits and drawbacks are accounted for.
    If you're considering throughput, as in, making sure the printer can keep up with the mill, to maintain part production without stall, that's a different management problem that's not new, and easily solved. If you have a secondary mill op for a part that starts on a lathe, and the mill op takes 2 minutes cycle, whereas the lathe takes 20 minutes, obviously you aren't going to set up and run both at the same time.
    I don't know what else comparing mill MMR to wire deposition rate would tell me.
  10. #9
    Oct 2011
    Michigan
    165
    19
    60
    Check out what Slade Garder is doing at Big Metal Additive (find the company on Instagram) for some large metal parts. He uses WAAM mostly with aluminum, because of the particular machines he uses.
    Your own example of starting with a large block and removing 90% of it, is one of the drivers for the technology, especially with expensive exotic alloys. Also repair work, as someone else pointed out. The other, as you guessed, for low volume (onesies and twosies) parts that people don't want to keep on the shelf, you'll see more and more companies investigating additive manufacturing for that particular use case.
  11. Likes JNieman liked this post
  12. #10
    Nov 2011
    Missouri, USA
    2,140
    1364
    2737
    Quote Originally Posted by jeffj View Post
    I've been a fan of Big Metal Additive for a while. I was put in touch with another engineer there a while back. Very cool stuff.
    There are case studies about being able to print train parts in Europe, where they had trouble getting reasonable quotes on forgings because they needed 2 parts, right? When you have to maintain a fleet of anything for 60 years... yea, you can't exactly keep a shelf full of anything that might break.
    I think the current buzzword the hot-air-balloon speakers are using is "digital warehouse".
    Or you know, what you and I would call CAD files.
  13. Likes jeffj liked this post
  14. #11
    Nov 2011
    Missouri, USA
    2,140
    1364
    2737
    There's a good intro-discussion article here about one of the really interesting points of an wire-fed additive process:
    Wire-arc additive manufacturing can be used to build very large parts to near-net shape
    Which is the ability to use different materials fully fused. Imagine laying down 90% of a mold with low carbon steel, and just applying the more expensive alloyed tool steel where necessary.
    I think them material opportunities are pretty interesting - not just from a mass/cost savings, but also from being able to optimize a "hybrid-material" part. Takes the old cladding and cold-spray abilities to another level.
