04-05-2019, 09:40 AM #1
Lead Screw - slight galling causing manufacturing
Hi,
I've had a few issues with galling which has caused the lead screw to loose its effectiveness.
The machined parts haven't been to spec. Can someone recommend a reliable lead screw brand?
04-08-2019, 11:34 AM #2
What type/brand of machine are you running? Is the lead screw you have just an ACME or Trapezoidal screw or is it a ballscrew?
04-10-2019, 09:11 AM #3
Its a trapezoidal lead screw in a lathe machine.
04-10-2019, 09:32 AM #4
What makes you think the problem is from the lead screw? Other factors can cause problems like cutting tool geometry. feeds and speeds,part or tool ridegitey, spindle bearings, other.
04-10-2019, 09:39 AM #5
04-10-2019, 11:06 AM #6
A little thrown off as this thread is in "Additive Manufacturing/3D Printing" but nonetheless I agree with digger doug as pictures of what you are describing would be helpful.
michiganbuck liked this post
04-10-2019, 11:10 AM #7
04-10-2019, 12:17 PM #8
04-10-2019, 04:45 PM #9
A printer goes many ways/travel direction..mostly a lathe goes/travels one way so after slack is taken up it should ride smooth.
04-13-2019, 10:14 AM #10
04-13-2019, 12:54 PM #11
04-15-2019, 01:15 PM #12
