Possible to 3D Print Wood Part? - Page 2
Page 2 of 2 FirstFirst 12
Results 21 to 25 of 25
  1. #21
    Jul 2015
    Missouri
    78
    93
    34
    It is possible to 3d print a part with wood content. Just not 100% wood. For a prototype then it should be more acceptable. Or another just plastic part to more closely simulate the stained color would be possible too.
    Amazon.com: MG Chemicals Wood 3D Printer Filament, 1.75mm, .5 Kg (1.1 lbs.) - Wood: Kitchen & Dining
  2. #22
    Oct 2005
    14,512
    Quote Originally Posted by Bill D View Post
    I think he means friction welding of wood. Of course the heat causes charring at the interface. I suppose if done in a vacuum the charring would be reduced.
    Bill D
    Uhm...no.
    It's a Hi freq wood glue curing (rapid curing) device.
    No welding involved.
    Been around a long time.
  3. #23
    Nov 2010
    UNITED KINGDOM
    976
    193
    236
    Some years ago I met a guy that worked at a place that made gear knobs with wood effect. He gave me one as I had a Jaguar XJ6 back then.
    He told me that the company he worked for, made wood effect trim and steering wheel for Jaguar cars and others, the trim was formed plywood which was dipped to get the wood effect, and then lacquered.
    Maybe looking into this manufacturing method could find a source for the parts, or finding out how it is done will provide a solution?
  4. #24
    Nov 2003
    Beaumont, TX, USA
    4,893
    171
    1483
  5. #25
    Jul 2014
    Ontario, Canada
    1,026
    731
    662
    I've recently become involved with a process that seeks to use fruit pulp as a form of textile 'leather'. The gist of it is that apple carcasses are dried, ground and mixed with a resin binder. It raises the question of when a material matrix ceases to be one of its constituents and is nothing more than particles held together by glue.
    The wood filament is mostly resin, is it not? Like the apple leather being called 'apple', I'd hardly call that 'wood. It has none of the structural or native properties of the original material. Not saying it's not available or marketed as such, just that we may be getting into a sad state of affairs wrt consumer materials.
