Seeking model-maker to replicate worn shredder gear
Results 1 to 14 of 14
    Mar 2011
    Westchester Co, NY
    7
    Default Seeking model-maker to replicate worn shredder gear
    One of the nylon gears on my Staples SPL-826x paper shredder is stripped and I'm interested in having a model created in order to print a replacement.
    I have rudimentary skills with Sketchup, but don't think I can produce a workable 3D model myself. It does have a metal hub (see picture), so that might be a complication when it comes to manufacturing it.
    Can folks advise on whether this sort of project sounds feasible, and if so on the best place to find someone who could create the model?
    Dec 2014
    CANADA
    British Columbia
    1,288
    361
    590
    Your best bet would be to find someone with the same shredder and a different broken part. No printed component is going to be strong enough to handle the loads that gear sees (your professionally made one wore out) so presuming you got a satisfactory life time out of that shredder it's probably best to just accept it's gone and move on with a replacement.
  3. Likes awander, TeachMePlease liked this post
    Jun 2016
    New York
    1,891
    1232
    905
    Quote Originally Posted by overhear View Post
    holy freakin' hayzoos, its a paper shredder! stop what you are thinking or doing, go to Goodwill, buy one for 20$, go back home, shred at will...
    Mar 2011
    Geneva Illinois USA
    6,454
    2826
    2535
    When I was a young tad, I used jobs like that to develop my machining skills. I think this fellow should buy a lathe (10" or bigger), a mill (horizontal is best for this), a dividing head, cutters, material and have at it. I made shower head inserts, storm window latches, all kinds of worthless stuff that would have cheaper to just buy.
    Tom
    Mar 2011
    Westchester Co, NY
    7
    Quote Originally Posted by Hazzert View Post
    I did poke around on craigslist, etc. for another one, but this model is ancient in shredder-years so no go.
    Mar 2011
    Westchester Co, NY
    7
    Quote Originally Posted by TDegenhart View Post
    Tom
    Yep, that's me. Except in my case the world's landfills are littered with things I've tried to "fix": Espresso machines, lawn mowers, radio. My success rate is frankly abysmal. But I do keep flailing away at these things. My father is in the used machinery business and has spent his career rebuilding things that were actually designed to last more than 6 months -- unlike the stuff we buy now. I was probably just born in the wrong century.
    But this might be a good excuse to buy that dremel tool I've been eyeing!
    May 2017
    Massachusetts
    387
    428
    200
    I wouldn't fret for a minute about the world's landfill being filled with objects you've tried to repair and fail. Take a philosophical approach. They were destined for the landfill before you got involved. You tried (and presumably sometimes succeeded) even if your record is 'abysmal'.
    That abysmal record is the seed of improvement in your own skill-set and competency. I'll hazard a guess you learned valuable skills/lessons on every one of those failures and over the arc of your life, your abysmal record is most likely improving.
    At least it improves every time for me.
    I'll echo the previous advice. No way it makes any sense for someone else to fix this for you. Makes tons of sense for you to use this as an opportunity to hone your skills. The 'value' isn't the fixed (or broken) shredder. It's the learning experience that makes you a better machinist.
    Make chips.
  9. Likes overhear, TDegenhart liked this post
  10. #8
    May 2014
    ca, US
    306
    81
    It appears to be a skew gear. Most simple CAD programs would have problems creating that. You can do it in AutoCAD R14 or newer. Go to RushGears or one of the other sites that will generate a dxf file of the tooth profile. Create a closed perimeter of one tooth and a line from the tip of the gear in the Z axis at the skew angle. Extrude it along the skew path. Polar array the one tooth into the whole gear and add all the parts.
    You will have to remove the nylon gear from the steel spur hub, model it and subtract it from the 3D model.
    Export the 3D model into a program that exports a .stl file. Then print it.
  11. Likes overhear liked this post
  12. #9
    Nov 2008
    Madera county california usa
    2,548
    21
    654
    If device is any good the manufacturer may have a replacement.
    Or...find suitable gear and mating gear and make a new drive pair.
  13. #10
    Apr 2008
    Michigan
    52
    38
    In the world of failures, a term known as "Root Cause Analysis" exists.
    It seeks out the true cause for something failing. The gear appears to have been held fast or obstructed from tuning freely.
    This fact/observation highly suggests an additional failure caused the gear to become damaged.
    Until the original cause or issue is resolved, replacing the damaged gear will not repair or solve the reason it failed in the first place.
    The crowd here tends to judge quickly the merits of other's pursuing something.
    It's not for the peanut gallery in a forum to decide... what you are interested in... or want to do.
    Make a new gear. Spend as much time, sweat and money on the project you care to expend.
    Fabricate seven more, or 32,000 additional gears.
    Before you do that though, find out why the gear failed and fix that problem first.
    That's what I can see from my vantage point here in the gallery ; )
    John
  14. #11
    Mar 2011
    Westchester Co, NY
    7
    Quote Originally Posted by d'Arsonval View Post
    John
    Good point. My assumption has been that the obstruction was an overload of paper that jammed the feeder. I suppose the nice thing about 3D fabrication is that you can make multiples, which allows you to test these hypotheses.
  15. #12
    Jan 2019
    Tennessee
    553
    177
    147
    stick with the skill route, it is more fun. go ahead and get the dermal, some silicone rubber mold, some wax, tooth picks, two drill bits, and a can of bondo glass. A set of cheap needle files too. These ingredients will make a reasonable strong gear, and because you have mold you can make multiples as you track down the cause of failure. Worst case is you have a dermal and a set of needle files.
  16. #13
    Jul 2004
    central NC
    2,608
    31
    683
    Quote Originally Posted by cyanidekid View Post
    When I was in the Army the "shredder" (officially called a disintegrator) was 6' tall by 4' by 4' and weighed about 1500 lbs, it was also tested and approved for use on classified material.
    Sometimes there actually are reasons why the simple, obvious solution isn't acceptable.
    Steve
  17. #14
    Mar 2019
    North Carolina
    30
    32
    I needed to replace a simple plastic spur gear in our Roomba. Roomba did not have the replacement part. I couldn't find the right size gear elsewhere. I was going to model it in Rhino (which would have been a quick job), then have it 3D-printed through one of the online services, but then I discovered that someone else had already modeled the same gear and shared it on the 3D printing service website. I think I paid about $10, with shipping, and the gear has been working well for several months now. This type of project is an area where 3D printers CAN be cost-effective. One less Roomba in the landfill (for a while) . . . .
