JHOLLAND1
Titanium
- Oct 8, 2005
- western washington state
so i swapped a mori seiki sl-1 lathe for a 1958 hyster challenger 50H lift truck--
it last ran in 1990
the 50H series were made from 1957 to 1979
the heat engine in this unit is 162 cu in ford
lift truck weight 9000 lb
the nissan shop lift is 5500 lb rated--btw this nissan is superb in every respect
in order to load the hyster on trailer it was necessary to drop counterweight
my guestimate was truck subframe would couple rear axle/tires/steering apparatus
allowing problem free lift off of counterweight
as i removed the last of 6 ---one inch dia bolts securing counterweight--the forward frame dropped
so the nissan was employed to lift frame 4 inches for blocking
with intent to lift counterweight following frame leveling--
as the truck frame lift progressed--an audible snap followed by heavy thud and 180 degree roll
of counterweight was witnessed
analysis of construction anatomy confirmed an unbelievable design error commited by usually
dependable hyster-- the steering axle was fastened to counterweight---even more troublesome---all weight and
travel shock force was borne by 6 threaded 1 inch fasterners with no structural element--such as load shelf
or bracket incorporated into design to serve as primary load bearing feature--with threaded fastener serving as
securing element with minimal load bearing intent
i reviewed factory service manual issued 1976---hyster makes no reference to this engineering disaster--
instructions for counterweight removal on later units clearly reference steering axle attached to truck frame
pics snapped today
it last ran in 1990
pics snapped today
