14 1/2 degree pressure angle gear rod stock from Grob in Grafton, WI
Results 1 to 9 of 9
    Jan 2019
    Virginia
    30
    6
    Thumbs up 14 1/2 degree pressure angle gear rod stock from Grob in Grafton, WI
    I needed a new 14 1/2 PA spur gear in a face width that I could not find. I've read from various sources that a 20 degree PA is compatible with 14 1/2 PA but vendors say otherwise. So I decided to match the original gear to avoid headaches.
    When I searched, I discovered that Grob Inc. sells 14 1/2 PA gear rod stock. They have an online tool to reverse engineer the diametral pitch. Dakota Koffarnus checked stock and found the correct rod stock. He cheerfully filled the smallest order they could do without a bunch of guff over a small order. The packing job was excellent. A heavy cardboard tube had wood ends inserted to protect the rod ends and the tube had a cut line line indicating where to saw it open. So I'll cut it to length, bore it, and wind up with a nice gear. At the same price as purchasing a single gear, I'll have enough left over to cut 20 or so more. I might even break even by selling them online. So if you're looking for 14 1/2 PA gear rod stock (some call it pinion wire), you might want to check out Grob.
    Apr 2010
    northeastern Pa, USA
    735
    151
    223
    What tooth count did you get in what DP? I may be interested.
    Jul 2006
    Hillsboro, New Hampshire
    9,313
    2207
    6458
    Nice to get a positive report on a vendor.
    Aug 2003
    port allen, louisiana usa
    1,788
    503
    422
    I saw in Boston Gear catalog years ago that 14 1/2 will NOT work with 20 degree pressure angle gears....Cheers; Ramsay 1
    Dec 2012
    AUSTRALIA
    2,888
    12
    943
    I know for a fact it wont .....however ..gear rod....sounds interesting ...but what size ....clock size gears ? or 10DP?
    Jan 2019
    Virginia
    30
    6
    It's a small gear:
    24 tooth
    o.d. = 1.071 (likely a bit off to age and wear)
    their formula #of teeth +2 / o.d. = DP
    so 24+2/.071 = 24.27
    14 1/2 degree PA
    my face width was 3/8" but since it's rod stock, you can cut what you need.
    bore size can be anything you want
    According to Dakota, for whatever reason, 1" (nominal dimension) would more likely an o.d. of 1.083"
    This makes sense. The gear is about 50 years old. So it's not difficult to believe
    that it wore by .012, or it just wasn't made to a precise level to begin with.
    Using the same formula:
    24+2 / 1.083 = 24.00739" DP, almost perfect
    So I ordered the gear rod stock with a DP of 24. If there is any difference between the new and old geometries, I can't detect it.
    Just FYI, I have seen two terms in use, "gear rod stock", and "pinion wire."
    Also, the alloy they had on the shelf was 4140, which should be more than adequate for a lathe gear moving at relatively low speeds.
    So a 12" piece of gear rod cost just over $50.00 with a cut charge, taxes, and deliver. Even if each cut wastes an additional 1/4" of width, this yields 24 gears.
    So materials are just over 2$ per gear.
    Jan 2019
    Virginia
    30
    6
    john.k:
    Their website specifically advertises gear rod stock and their ability to make whatever you want. They apparently maintain a stock of drops and rods in the sixish foot lengths of various 14 1/2 DP sizes. You can always call or E-mail (I'd recommend email) to see if they can match what you're looking for from their existing inventory. Good luck.
    Mar 2017
    234
    104
    It's probably called pinion wire as a holdover from the days when clockmakers used it. It was made in module sizes using drawplates. Not modern tooth forms, however.
    Jan 2004
    313
    20
    53
    Very informative post. Thank you very much!!
    I've bookmarked their website.
