tommy1010
Stainless
- Apr 21, 2010
- northeastern Pa, USA
I am currently rebuilding a 16" Hendey Tie Bar. I am currently reassembling the QCGB. As all Hendey owners know the lead screw goes through the entire gear box cone gears sticking out in my case a good 4 feet or more. This is a little cumbersome when installing the gear box or saddle back onto the machine. Has anyone reading this post ever cut the lead screw and then fastened it with a coupling. As seen in the pics attached the first 16" of the lead screw are in the gearbox. The unthreaded portion of the lead screw is about 15" long and already has a 1/4" keyway. This is where I would like to cut then couple. A sleeve with 1/4" keyway and some set screws or tapered pins about 4" long. I don't believe the saddle comes that close to the QCGB. Maybe 4" is too long? Anyone here done this and how? I have had a few machines (not Hendeys) with the lead screw coupled from the factory so I don't think this should be a problem.
