tommy1010
Stainless
- Apr 21, 2010
- northeastern Pa, USA
Here are couple of quick pics of the progress I have made since we cannot go anywhere. The one shows the QCGB reassembled with the lead screw cut off and has the coupling on the lead screw. The other is the three position gear box that bolts to the QCGB. The other two are the half nuts. They are not the largest I have seen but they are pretty big. Hendey owners may know this already but the half nuts are cast into the cast iron body. If you look close you can see where the metal shows through the non threaded side as a lighter grey/silver color. It is not soft by any means. Maybe someone here knows what alloy it is.
