1900s-1940s frick compressors
Results 1 to 17 of 17
    Oct 2021
    Missouri
    Default 1900s-1940s frick compressors
    A buddy of mine is demolishing a warehouse and I recovered some machines / parts. I know there is a market out there for them but I am struggling finding any information on them.
    What are they worth? What do I need to search to find information?
    Imgur: The magic of the Internet
    Feb 2011
    BFE Nevada/San Marcos Tx
    3,339
    3295
    2089
    iirc Frick made ammonia compressors
  3. Likes 4GSR liked this post
    Oct 2005
    22,780
    Quote Originally Posted by Stldrew View Post
    Don't bother, make more money by selling to the steampunk crowd.
    Jul 2004
    Houston, TX USA
    32,455
    I wonder if any ties to Henry Clay Frick the foundry / steel making COKE king
    May 2003
    Michigan
    3,101
    1789
    1558
    There worth scrap.
    There not related to Frick of coke making, but they are related to Frick of steam traction engine building.
    Mar 2007
    L'Orignal, Ontario Canada
    2,445
    2708
    1103
    I can't help with the value but there are several mentions of Frick in other older threads on this forum if you use the Forum Search feature.
    Here is one of them .
    Frick , Norwalk & Baker Compressor Information
    Jim
    Feb 2011
    3,339
    3295
    2089
    I don't think they have any value in commerce other than as scrap metal. They may have something better than scrap value to someone wanting to use one in an antique display or to someone wanting to convert it to an internal combustion engine, but don't get too greedy.
  9. #8
    May 2020
    Minnesota
    578
    239
    245
    Definitely refrigerant pumps.
    Not worth a whole lot in terms of usefulness - mostly collector's value.
    You could convert them to run as air compressors if you equip them for through-lubrication. E.g. an oil fogger on the intake and an oil trap on the discharge. AFAIK all refrigerant pumps are designed to use either the refrigerant or an oil that is blended into it for lubrication. The how or why of it I'm admittedly not familiar with.
  10. #9
    Dec 2012
    AUSTRALIA
    5,075
    35
    1837
    I believe Frick was a maker of steam tractors and engines,when the founder died,the works passed in to other hands ,and was a maker of refrigeration compressors.......anyhoo,as mentioned most (not all) refrigeration compressors use oil dissolved in the refrigerant and circulating with it.....I think big (50 ton) ammonia compressors are separately lubricated,as ammonia works at quite high pressure,like 1000psi................When I was a wee lad,we used to salvage refrigeration bits ,and in those days common gasses in old systems was sulfur dioxide,methyl chloride ,and ammonia......you had to be careful ,as every bolt hole would be full of the highly volatile liquid,and undoing a bolt might be accompanied by a squirt of caustic liquid .
  11. Likes JoeE. liked this post
  12. #10
    Dec 2012
    AUSTRALIA
    5,075
    35
    1837
    The lubricator shown has value.....a brass biggie of famous make can sell for $1000 to a collector...........brass gauges also fetch up to $100 each.
  13. #11
    Oct 2021
    Missouri
    Thank you for the info. I appreciate it!
  14. #12
    Jul 2007
    Missoula Mt
    1,449
    62
    733
    Save the oilier, gauges, and the pulleys...scrap the rest...Phil
  15. #13
    Jan 2005
    Victoria, Texas, USA
    4,887
    3603
    1397
    Frick compressors are still built today under Johnson Controls.
    https://www.johnsoncontrols.com/indu...essor-packages
    Of course, they would not be interested or even offer repair parts for something this old. Could be wrong.
  16. #14
    Dec 2012
    AUSTRALIA
    5,075
    35
    1837
    The compressors have an interesting construction.....what appears to be a cylinder head held down by bolts is actually a gas tight cover......the head of each cylinder is actually held down by a very strong spring inside the cover ...the idea is that a slug of liquid passing through the cylinder wont smash the piston and rod due to incompressability......the compression ratio is very high as any free space reduces efficiency ........Anyhoo,my point is if you undo all the head bolts,the spring inside may propel the 100lb+ cover with great force as the gasket breaks.
  17. #15
    Feb 2011
    3,339
    3295
    2089
    Quote Originally Posted by 4GSR View Post
    Is Frick India part of Johnson Controls?
    Industrial Refrigeration-Ammonia Compressors-Refrigeration Equipment Manufacturer
  18. #16
    Jan 2005
    4,887
    3603
    1397
    Quote Originally Posted by dalmatiangirl61 View Post
    According to their website, they have no connection with Frick USA. Hummm.
  19. #17
    Feb 2011
    3,339
    3295
    2089
    I missed that line, interesting, I wonder what the story is? I'm envisioning a 3rd cousin that was not happy with the sale and absconded to India with a filing cabinet full of drawings
  20. Likes 4GSR liked this post
