1905 Bullard VBM Clutch Question
Page 1 of 2 12 LastLast
Results 1 to 20 of 34
    Jan 2004
    Columbia, PA, USA
    298
    13
    46
    Default 1905 Bullard VBM Clutch Question
    I've recently purchased a 1905 rapid production Bullard VBM with a 37.5" diameter table. The previous owners added an electric motor with v-belts to directly drive the machine. So, when the start button is pushed the table begins to turn immediately. That's completely unacceptable to me. I've researched pictures of Bullard vtl's with clutches. My question, does anybody know what clutch manufacturer Bullard used of this time period?
    Feb 2013
    Houston TX
    3,809
    16
    1861
    At work nearly all the VTLs have been set up on VFDs.
    Be simpler than trying to find/make/adapt a clutch to a 114 year old machine
    Sent from my SM-G965U using Tapatalk
    Oct 2005
    14,548
    Quote Originally Posted by alskdjfhg View Post
    YUP.
    FWIW the newer (much newer) Dynatrol bullards were "push to start".
    They engaged a clutch with hydraulic pressure, so I'll bet they had speed limit
    valves on the solenoid.
    Just use a VFD as mentioned above.
    Dec 2010
    Mifflintown, PA 17059
    1,747
    20
    187
    I had a similar Bullard, the clutch arm was low near the floor, I used my foot, I assumed that was how it was intended to be used. It had run in oil disk clutches, as per Bullard the SN checked and it was made in 1910. Flat belt was removed, Vee belt pulley added and motor mounted in the rear, machine worked great! I can check to see if I have any old manuals. I did get one from Bullard at the time, wasn't much only a few copied pages for $100!! However when Bullard was still in business they told me all parts were available.
  5. Likes Custommachining liked this post
    Feb 2013
    Houston TX
    3,809
    16
    1861
    YUP.
    The ones that dont have VFDs are push to start. And a jog button is just be a momentary contact to the motor starter. So jog is normal turning speed, just shuts the motor off when you dont press the button.
    Not sure why the push button start would be a problem.
    Oct 2005
    14,548
    I'm pretty sure when I used to run the 54" one, the motor was started
    at some buttons on the side, and ran all day.
    The pendant had a dial for table speeds, with detents.
    A start stop button shifted a hydraulic solenoid in back in "the drawer".
    Jan 2004
    Columbia, PA, USA
    298
    13
    46
    Quote Originally Posted by Froneck View Post
    If I could purchase an old manual from you that would be greatly appreciated. Thank you.
  9. #8
    Jan 2004
    Columbia, PA, USA
    298
    13
    46
    I guess I'm more comfortable with a clutch where you can ease into it.
  10. #9
    Sep 2005
    Illinois
    391
    43
    I have to tell yo I would love to see some pics, I have a 1910 Bullard VBM New Era. 54" table . It kinda sounds like yours where a pully for V belts were added and by someone in the past. I looked some years ago and was told by an old timer that back in them days there were no manuals. I don't know if there is any truth to I but he said back in them days sometimes they would send out a rep to show how it works. That may have been cheaper than printing up all kinds of manuals. Like I said I don't know this to be true, just what I was told. I will get some pics of mine and post them . I also did a google search and found Patent drawings that showed the drive system pretty well. mike
  11. Likes Custommachining liked this post
  12. #10
    Oct 2005
    14,548
    Quote Originally Posted by Custommachining View Post
    I am too, but you get used to it, and if you put a VFD on it, with the speed pot
    on a pendant, you could ramp it up as slow as you would like.
  13. Likes Custommachining liked this post
  14. #11
    Dec 2010
    1,747
    20
    187
    If I still had that manual I'd send it to you! I did buy a pile of manuals from Curtis-Wright, they had just about every machine manual ever made in their maintenance files. Most I gave away or sold. I'll look to see what I have but I know the manual I bought from Bullard went with the machine.
    I too like the clutch as opposed to the electronic control and the foot operated clutch on the Bullard was great, 2 hands free to do something else while my foot controlled spindle rotation and brake.
  15. #12
    Apr 2013
    Damascus, MD
    1,396
    4005
    792
    I don't have direct experience with Bullard VBMs. However, at Tuckahoe we do have two Bullard VTL, both driven with flat belt.
    The older one has a cone pulley and no clutch, The "younger one" (late teens, I believe) has a single pulley and an internal gearbox and a clutch. Personally, I would be extremely hesitant in bypassing the clutch in that machine. My understanding is that there is an oil pump powered by the input shaft and that oil pump is supposed to run always, not only when the clutch is engaged.
    If the machine has been designed to be run that way, you probably risk to accelerate significantly the wear if you start the spindle at the same time as the oil pump.
    If the machine in question is early enough not to have any oil pump, probably it doesn't matter much as long as all parts are generously lubricated before starting.
    Paolo
  16. #13
    Apr 2013
    Damascus, MD
    1,396
    4005
    792
    Sorry, I'm rather slow in connecting the dots. If the VTL in question is the one from this thread (Price Filler Machine Shop in Roanoke, VA), I don't believe it had any clutch in the first place.
    Together with other Tuckahoe volunteers we went there inspecting that and other machines. Unfortunately, I didn't take great pictures of that one, thinking that we would get it into our Museum. One thing that I remember is the loud noise of the bevel gears driving the spindle and I suspected that the bearing was worn too much and the gears meshing too tight.
    Paolo
  17. Likes Custommachining liked this post
  18. #14
    Jan 2004
    Columbia, PA, USA
    298
    13
    46
    Yes I'll post some pictures this evening
  19. #15
    Jan 2004
    Columbia, PA, USA
    298
    13
    46
    Default 1905 Bullard VBM Pictures
    Here are a few pictures of the machine.
    Attached Thumbnails Attached Thumbnails 20190411_184524.jpg   20190411_184500.jpg   20190411_184551.jpg   20190411_184627.jpg   20190411_184647.jpg
  20. Likes rbdjr59, Peter S liked this post
  21. #16
    Feb 2013
    Houston TX
    3,809
    16
    1861
    That's a beauty. Most likley used a moveable pulley on the line shaft to start and stop the machine, no clutch as such
  22. Likes Paolo_MD liked this post
  23. #17
    Jan 2004
    Columbia, PA, USA
    298
    13
    46
    More pictures....can someone give me a heads-up on how to rotate pictures. The pictures are upright in my computer but become rotated when I download to the site.......???
    Attached Thumbnails Attached Thumbnails 20190411_184751.jpg   20190411_184732.jpg   20190411_185037.jpg   20190411_184840.jpg   20190411_184658.jpg
  24. Likes rbdjr59 liked this post
  25. #18
    Jan 2004
    Columbia, PA, USA
    298
    13
    46
    More pictures.....
    Attached Thumbnails Attached Thumbnails 20190411_185216.jpg   20190411_185004.jpg   20190411_185016.jpg   20190411_185153.jpg
  26. Likes rbdjr59 liked this post
  27. #19
    Jan 2004
    Columbia, PA, USA
    298
    13
    46
    Default 1905 Bullard VBM Clutch Assembly
    This what I'm installing on the VBM. Scroll down once the page becomes available after clicking on the hyperlink below.
    https://www.ebay.com/itm/Brown-Sharp...97.m4902.l9144
  28. #20
    Jul 2009
    Munster, In. USA
    2,276
    455
    680
    Flippin' da Photags:
    John
