1920 Lodge and Shipley 18" selective head
Results 1 to 19 of 19
    Jun 2017
    Virginia
    8
    Default 1920 Lodge and Shipley 18" selective head
    I have a 1920s Lodge and Shipley 18" x 54" selective head in Norfolk VA that needs a new home. It comes with an Armstrong quick change toolpost, a few holders and some tool steels. The machine has a low speed 7.5 hp motor with plenty of grunt transfered by a 4" flatbelt all mounted to the machine. It has a quick selection threading gearbox/tumbler that works fine. It has a taper attachment that needs a bed clamp. one of the gear selectors has a gear that doesn't select, I have what I think is the gear to replace it that came with the machine, I have just never looked into it. There is minor damage here and there from living in industrial environments for 100 years, but it is all there. I stripped most of the many layers of paint, so most of that work is done. The lathe is perfectly functional as is, but could use a few odds and ends.
    Anyone with 200$ that isn't going to scrap it is welcome to it.
    I need to make room for machines that fit my needs better (carbide speeds).
    Mike
  2. Likes ClappedOutBport liked this post
  3. #2
    Jul 2004
    Houston, TX USA
    30,868
    like so - thanks to Mike C for the 1916 scan
    Jun 2017
    Virginia
    8
    That's the one. It has a large 4 jaw on it currently, and comes with a fabricated chip pan. The motor is mounted on top of the head stock, but I have commonly seen them mounted below, closer to the floor. I think the mount is original, or at least very well executed.
    Jul 2004
    Houston, TX USA
    30,868
    Quote Originally Posted by Rotary Science View Post
    Sort of like so - with the little idler adding to "belt wrap" on the motor pulley. Adds to the "stump puller" aspect of these lathes
    Dec 2010
    Mifflintown, PA 17059
    1,913
    25
    239
    If anyone is interested I have the repair parts manual for this 1920's L&S lathe, it's 6 pages in the loose leaf format as in John's photos. I can post photos if requested.
    Jul 2004
    Houston, TX USA
    30,868
    Quote Originally Posted by Froneck View Post
    Funny thing about my edition of that (Bulletin No. 368 - dated February 1926) - some of the parts photos are from about early 1900s - immediately apparent if you are working on a late teens / early twenties apron
    Dec 2010
    1,913
    25
    239
    On the back page "PUBLICATION No. 478-S-637-Supersedes Bulletin No. 407" is printed and written exactly as it is. Has "Photos" of different head stocks with the top cover removed. I try to make a few photos tonight.
  9. #8
    Mar 2007
    On Elk Mountain, West Virginia, USA
    2,119
    936
    738
    What kind of facilities do you have to load on a flatbed truck?
  10. #9
    Jun 2017
    Virginia
    8
    I don't have any real lifting capacity on location. There is a local rental place that can drop off and pick up a forklift at a reasonable rate.
  11. #10
    Jul 2004
    Houston, TX USA
    30,868
    The 1916 page I posted above says 3500 for six foot bed and 350 additional for 2 more feet of bed. Later ones - like up to 1927 when the "star knob" apron clutches became levers- will very likely weigh more
  12. #11
    Dec 2010
    1,913
    25
    239
    Sorry, I promised to post a few photos of the manual I have. Made the photos but for some reason my computer can't link to my camera though it's been working fine for years and just a short while ago. I have 3 of the same cameras, none will connect including one that's was still in the box never used! I changed USB ports, connecting leads, cameras and docking stations. Still will not connect! Have an old wired mouse and it will work in all the ports. When I put the camera in the docking station I get the chime, remove it and get the chime again so something is connected.
  13. #12
    Jul 2004
    Houston, TX USA
    30,868
    Here is that odd page from February 1926 showing 1900ish apron parts
  14. #13
    Jul 2009
    Munster, In. USA
    2,477
    522
    797
    First image is from Bulletin 261-3821 and the second is copied and tweaked from johnoder's post # 2.
    John
  15. #14
    Dec 2010
    1,913
    25
    239
    Manual I have has quite a bit more information. My computer pissed me off, printer that has been working great will now not work to print but I can scan and copy using the computer but when I want to print I get a message printer not connected! Ordered new computer! Will be here hy the end of the week so I can get the photos posted. soon.
  16. #15
    Jul 2009
    Munster, In. USA
    2,477
    522
    797
    Delete the printer, the let the computer search for a new device and it should "find" the printer.
    May or may not have to reboot.
    Johhn
  17. #16
    Dec 2010
    1,913
    25
    239
    Quote Originally Posted by jhruska View Post
    Johhn
    Unfortunatly I did all that and more. I have had similar problems in the past every time I got an up-date but was able to get things working again. New computer is due today, I'll see how much time I have to play with it.
  18. #17
    Jun 2017
    Virginia
    8
    img_20200525_142555579.jpgimg_20200525_142544250.jpgimg_20200525_142539473.jpgimg_20200525_142533509_hdr.jpg
    Here are a few shots of the lathe
  19. #18
    Jul 2009
    Munster, In. USA
    2,477
    522
    797
    Photo flip
    John
  20. #19
    Jun 2017
    Virginia
    8
    This one sold locally. Thanks folks.
