1937 SB Dial Updates
Results 1 to 15 of 15
    Feb 2018
    West Virginia
    6
    Default 1937 SB Dial Updates
    SB may have the parts, but they won't help unless I have part numbers. I suppose there are other places that make larger dials, but I can't find them. Any help is appreciated. Thanks.
    Sep 2010
    moscow,ohio
    6,273
    643
    2067
    the only info you gave is "SB"....we assume that is South Bend but thAt is all anyone knows.
    Feb 2018
    West Virginia
    6
    Correct. It is a South Bend 9 inch lathe with a 4ft 6in bed. It has only 3 speeds, and was made in 1937. It has small dials. I'm hoping to replace the dials (and corresponding nuts) with larger dials.
    Feb 2004
    Traverse City, MI
    3,364
    126
    144
    The source for used ones is Ebay.
    Jul 2004
    Houston, TX USA
    30,716
    And three more slow BACK GEAR speeds (unless broken or missing parts) - when you figure that out
    Have one of these?
    http://vintagemachinery.org/pubs/1617/5795.pdf
    Feb 2018
    West Virginia
    6
    Really close. Except mine is only 3 speeds. You can see how small the cross-feed and compound dials are. I'm hoping to find larger dials. SouthBend/Gridley won't help unless I have the part numbers. Thanks for the manual.
    Jul 2010
    Virginia, USA
    3,516
    87
    670
    As john said, all south bend cone heads had backgear, so you have 6 speeds. Also, the modern SB won't have the dials anyway. Can you show us pics of your lathe? SB made two different generations of 9" lathes in 1937...
    allan
  8. Likes alum100k liked this post
  9. #8
    Apr 2010
    northeastern Pa, USA
    727
    148
    220
    It is not just the dials you need. It is far more than you realize to replace the small ones with a larger dial. It will be cheaper to get a DRO for the machine and not need the dials anymore.
  10. #9
    Feb 2018
    West Virginia
    6
    Here is a picture of my lathe. No luck on EBay, or I'm looking for the wrong thing.20200402_211715.jpg
    What is a DRO?
    Will a compound from a 10 inch lathe fit on the 9 inch?
  11. #10
    Jan 2019
    Virginia
    245
    172
    37
    So then there is a thing called.. "earned it". You can't buy it.
    Diamond recommends in particular way. The entire South Bend Handbook. It is most appealing these decades afterwards.
  12. #11
    Jul 2010
    Virginia, USA
    3,516
    87
    670
    ok, that's the 9" workshop, so parts are a bit more common. You should eventually be able to find a set of dials on ebay, or ted might have some ([email protected]). You'll also need some other parts that go along with the dials, like the various flanges and bushings around them. Those parts are more easily made than the dials however, so you can make them yourself. If you go that route, then any dial roughly the right size with the right number of graduations will do, even if it is not SB.
    I have a a bridgeport table dial here waiting to go on one of my lathes cross feed...
    allan
  13. #12
    Jul 2010
    Virginia, USA
    3,516
    87
    670
    Oh, and no- the compound would have to come from another 9" workshop. The 10K is too tall, the 10L has the wrong size mounting flange (and is probably too tall).
    allan
  14. #13
    Dec 2009
    Dearborn, Michigan
    1,335
    100
    242
    That lever on the top right of your head stock engages the back gear, and when you engage/disengage the bull gear pin you will discover your lathe has three more speeds.
  15. Likes jgestar liked this post
  16. #14
    Apr 2013
    Damascus, MD
    1,512
    4439
    860
    I guess you meant top left (circled in the picture). The one on the right is to put under tension the belt.
    Paolo
  17. #15
    Dec 2009
    Dearborn, Michigan
    1,335
    100
    242
    Quote Originally Posted by Paolo_MD View Post
    Paolo
    Yeah...yeah....that's what I meant.....
