1945 Leblond Regal 21” x 102” lathe motor and pulley help
Results 1 to 10 of 10
    Oct 2019
    North Carolina
    6
    Default 1945 Leblond Regal 21” x 102” lathe motor and pulley help
    I bought a nice old leblond regal 21”x102”. The motor and motor pulley is missing. I contacted leblond ltd and got build info. It had a 220v AC 3ph 5hp motor when shipped. They didn’t have a frame size or pulley info. I need both or if and one has these parts I can purchase
    Jul 2004
    Houston, TX USA
    29,656
    Put it in top gear. See what the speed was for that
    Engage clutch
    Turn clutch pulley enough turns to make chuck turn ONE TURN
    What was the turns count?
    Measure clutch pulley dia.
    Post all that info and I'll help you arrive at a motor pulley dia
    Its the simplest sort of math
    Original 5HP frame sizes in 1945 would have been 254 for 1750 and 284 for 1150 motors
    You may not find a frame size that is exact, so plan on making some 5 HP motor fit what is there
    I'd suggest 1150 or 1750 RPM 5 HP 3 phase - or single phase if that suits you better
    Regal stuff near bottom
    R. K. LeBlond Machine Tool Co. - Publication Reprints | VintageMachinery.org
    ph
  3. Likes cyanidekid liked this post
    Oct 2019
    North Carolina
    6
    Ok John will do. I’ve found a motor. Going with 254 7.5 hp 1755 rpm. Should work good
    Oct 2019
    North Carolina
    6
    My clutch pulley is 16”. It’s 1 to 1 with chuck.
    Jul 2004
    Houston, TX USA
    29,656
    Quote Originally Posted by Rdeere View Post
    So.......4" pulley and 1750 would get you 438 in what ever gear you had it in for the 1 to 1. You may want a 6" for 656 - and so on. I have yet to find out what LeBlond thought they should top out at.
    On the slower, the math was 16/4 = 4 and 1750 / 4 = 438
    Oct 2019
    North Carolina
    6
    A friend of mine has a 20 lodge and Shipley. Same size clutch pulley and motor speed. It has a 8” motor pulley. Was thinking that’s what my work would be 2 to 1 ratio so 16/8=2 and 1750/2=875
    Jul 2004
    Houston, TX USA
    29,656
    Here is the '46 17" brochure - says 425 top end or if you like increase by 50% for carbide
    I'd suppose the 21 was maybe a bit less as to speed
    http://vintagemachinery.org/pubs/2102/17794.pdf
  9. #8
    Oct 2019
    North Carolina
    6
    I ended up with a 3.75 pulley. That’s as close to original spindle speed I can get. Speed chart shows 358 rpm in high gear.
  10. #9
    Oct 2019
    North Carolina
    6
    16/3.75=4.27. 1785/4.27=418rpm. I believe that will be close enough. Thanks for your help and info.
  11. #10
    Jul 2004
    Houston, TX USA
    29,656
    Glad it all worked out useful like
