Results 1 to 4 of 4
05-15-2019, 06:02 PM #1
1968 Summit Horizontal/Vertical Mill
I am having a difficult time tracking any kind of information down on this machine. No manuals from Summit, no online notes, nothing about a model UNu... anywhere. About the only thing I have found is a couple of machines for sale that are seemingly identical.
Probably a long shot, but if anyone has some any information on this guy, I would love to see it.
Summit Brand (Although Summit says this machine may have been part of Hart Ind. before/while Summit bought them out)
Built in 1968
Model UNu (yes, the second u is lower case)
10 1/2" x 47" Plain Table (No swivel)
5HP Spindle
1HP Feed Motor
Seems to be built in Italy (although a few controls are in French)
~3500lbs.
40 Taper (Horizontal & Vertical)
Power feed + Rapid in all three axis
25-1500RPM
3/8" - 90 IPM Feedrates
The machine is in running order, but the vertical head and X axis nut need a little attention. Past that, I'd like to get a feel for the machine in action, and if it proves to work reliably, give it a DRO, a coat of paint and a permanent spot in the shop.
05-17-2019, 01:09 AM #2
I've been intrigued by machines further away. Because they weren't influenced too much, they come out with different engineering. That looks a great machine to me. The central motor drive is so cool because it powers all axis without hanging off. That means there are really intricate parts inside.
05-17-2019, 02:17 AM #3
Pretty standard lookin plain horizontal mill,with a plain vertical head..........any intricate gears will be in the knee.......where rapids are often broken.....but you can live with that.
11-11-2019, 03:49 PM #4
Well, I have an update!
First, a comment hinted that this could be an Induma mill. A few quick searches showed mills that were built suspiciously close to my machine, but not exactly the same. I figured it, for sure, had to be and an Induma.
A random search finally brought me to Simplon, another Italian company that also made similar machines. More specifically, a Simplon model UN (although mine does not have the universal table).
Of course, lathe.co.uk, had the information I needed the whole time:
Simplon UN Milling Machine
