2 phase Whiton Centering Lathe Machine - Page 2
Page 2 of 2 FirstFirst 12
Results 21 to 25 of 25
  1. #21
    Jun 2001
    St Louis
    17,636
    1709
    2908
    Quote Originally Posted by IrbyJones View Post
    Running 2 phase motors using a RPC was discussed in this thread:
    Single-phase to Two-phase and Three-phase
    I get a headache trying to follow it all, but it shows how to achieve it. And since you have a rotary convertor, Mike, maybe your brother can help you get that old motor running with help from that thread.
    Irby
    The short story is that with an RPC operating from the standard 240V single phase, you have a neutral on the incoming 240V. The voltage from the neutral to the generated leg of the RPC is at 90 deg to the incoming single phase, but is at a lower voltage. The idea expressed is to use a boost transformer to raise that to the 240V to get the 90 degree phase shifted voltage needed.
    That works as far as the phase shift, but may not work with a particular motor because it is effectively a "4 wire source".
    The. 2 phase came in 3 wire and 4 wire varieties, and I do not know which was more common or which your motor uses. The 4 wire motor has two independent windings. The 3 wire has a common lead that is connected to one wire of each winding.
    Motors using 3 wires would not be reversible, if they have 4 wires, they would be, and would work on either a 4 wire or 3 wire source
    The RPC-derived 2 phase needs a 4 wire motor, because the neutral is obviously not common with either leg of the 240V, and that voltage needs an independently connected winding... a 4 wire motor.
  2. Likes IrbyJones liked this post
  3. #22
    Aug 2014
    bainbridge island
    1,044
    196
    252
    keep in mind that you will have to program the vfd for linear volts per hz with very little "boost" volts. because otherwise you saturate the transformers and short out the vfd. so you're not going to get full torque below perhaps 30hz because you won't be able to shove enough volts into the motor to get the current you need.
    buck boost transformers usually have a 16/32 or 12/24 secondary and a 120/240 primary. you need a 32:208 ratio which is similar to a 37:240v transformer.
    a 40 volt secondary, 240v primary transformer would be a good option for that transformer. due to voltage drop under load, a 48volt transformer would probably work as well.
  4. #23
    Aug 2012
    Lower Thumb, Michigan
    187
    43
    129
    Yes, it is a 4 wire motor.
    Thanks for the sketch!
    It looks like the Everglades to me, but, maybe my brother can figure it out.
    I have some friends out East and have asked them to watch for a 2 phase motor for me, to add on like northernsinger suggested.
    This one is 1 1/2 hp, so, I would guess I need one at least as big, if not twice the size, like is called out for a common converter.
    If anyone has an extra one laying around, I'm game for a road trip.
    Mike
  5. #24
    Aug 2012
    187
    43
    129
    Several years ago, I bought a book to try to teach this old dog new tricks, but, I have not spent the time to absorb much of it.
    But, I thought I'd post some of the pages here for clarity on what a 2 phase motor is, in case any one does another search.
    If copyright rules make this wrong, please delete this post.
    Mike
    ...and, no, I have not solved my 2 phase issue with this motor yet...
    Electric Motor Repair
    Robert Rosenberg
    Murray-Hill Books
    1946
  6. #25
    Aug 2012
    187
    43
    129
