No not the direction shifter actually, it works better on this Hendey than any Hendey I have ever owned. Machine is in excellent condition, I'm not very generous with ratings! Carriage feed lever next to the Carriage hand wheel that when lifted-up will engage the carriage feed, but not cross feed which of course is a different lever. In this case carriage direction was set to travel toward the chuck and cross feed away from work. (feed direction lever down) Carriage was cutting .001/side (.002 Dia.) traveling toward chuck, as I got close to the dial carriage stop (original Hendey stop). I dropped the carriage feed lever, using the hand wheel I moved the carriage to the stop. (it did feel as it moved slightly probably taking-up gear backlash) I then engaged cross feed and it began feeding out. I soon noticed I was cutting an angle, carriage stop was pushed about 1/4", flipped the feed direction to neutral so all feeds stopped. Pushed down (off) cross feed lever and backed the tool out away from the work. Loosened the clamp for the carriage stop and moved it away form the carriage. Moved the carriage hand wheel left and right and I heard feed release. Was trying to get something done so I didn't have time to go back and check if carriage feed will stick again. Work was long but amount to be turned short so I was taking light cuts, .030 max. Must have made 10 cuts all doing the same thing as I got near the stop except use cross feed though I did use cross feed earlier to square-up shoulder so finial shoulder cut will be very small, just for finish. Carriage feed worked great every time.
