Froneck
Titanium
- Dec 4, 2010
- McClure, PA 17059
I completely dismantled my 14" Hendey tail Stock. Painted the Handles and the main 2 castings. I fitted a thrust bearing on the screw, drilled and tapped holes for future way wiper installation. Drilled and reamed 2 holes for angle Gits oil cups to oil the ways and made an opening in the ways for felt to be fed oil from the Gits fittings. I even painted the adjustment screws. Not much, masking taped the threads and the square flats for the wrench and painted the little that is still exposed.
BUT!!! I removed the lower clamp assembly. Putting the Tail Stock together I found everything except the bar that fits on the eye bolt, the clamp and the clamping screw! I've looked everywhere! I have the pin with the cotter pins, the other long pin that holds the bar on the clamp, the set screws that hold the pin and the tightening screw + the painted wrench. All of them are cleaned and ready to be installed except the clamp that I will finish cleaning and paint as soon as I can find the bar. Why it's not near the lathe like all the other parts I don't know. Maybe I painted it and it's hanging someplace or worse bumped and it feel into a cranny. I looked at parts book and can see one side. Anyone have any other views or dimensions. I might be looking but don't recognize another view. Maybe a few photos?
