TomB
In the USA, railroads, back in steam locomotive days, often specified Whitworth threads on boiler staybolts. Possibly the belief is the 55 degree angle makes a slightly stronger thread, and possibly, the slight radius' at the crests and roots of the Whitworth threads make for less stress risers. Boiler staybolt threads are loaded in shear, and the staybolts are usually tapped into boiler sheets that are a good bit thinner than the nominal diameter of the staybolts. A few threads engagement have a lot of work to do. Admittedly, screwed stays had the ends hammered over (peened like a rivet head). But the sheets saw thermal and pressure cycling, some flexing, and the stays had s lot going on in the way of stresses and cyclical stresses. For whatever reason, the railroads and locomotive builders in the USA sometimes spec'd Whitworth threads on boiler staybolts.
We can go back into the demographics of the railroads, and in the 1800's, into the 20th Century, a lot of the supervision and management were of English stock. It was not uncommon on US railroads in the 1800's to find English immigrants as shop foremen and as locomotive engineers. There was a certain heirarchy on the US railroads, at least in the Northeastern USA. If a person was of English, Scottish, or German stock, they could enter the shops or engine service and rise in the ranks. If a person was from Southern Europe (Italian), or Eastern Europe (Russians, Poles, Hungarians,) they were not likely to be allowed to advance too far and often limited in what departments they could work in. The English master mechanics or shop foremen stuck to what they knew, and it went beyond the shops and locomotives to the people they hired. I would not be surprised- not that we will know the answer- to find that some master mechanic who'd come from England brought the idea of the 77 degree center with him.
I know that there was considerable transfer and sharing of knowledge between US, European, and British railroads and locomotive builders. Old trade and engineering journals often have articles about the latest practice or new developments in England or Europe. Even before the internet and the ease with which we can access all sorts of information, people in the different professions and industries communicated by way of published papers, articles in journals, or by travelling and visiting examples of their particular industry or field in some other country. It could well be that the 77 degree center idea came from something ranging from a published paper or article, or from some US master mechanic or mechanical engineer visiting British "works" and discussing problems and what working practices they were using.
As to why it was abandoned, we come back to advances in a multitude of areas, and we come back to standardization. The US seemed to have settled on 60 degrees for the included angle of lathe centers. tooling manufacturers were offering centers with the 60 degree angle. High speed steels and then live centers came on the scene, so the need for a center with increased bearing and shear areas was not as critical as it had been when using carbon steel dead centers. Then, the steam locomotives passed from the scene and electric and diesel locomotives took over. Smaller driving wheels, lighter loads on the wheel lathe centers.
I suppose the 77 degree vs 60 degree lathe center question would come down to some trial-and-error experimentation with steam locomotive driving wheel sets (two drivers mounted on their axle) in a wheel lathe. Seeing which center angle gave the best support, and then experimenting with turning axles in a lathe with a tailstock dead center and seeing which center angle did not heat up as much and could withstand the heaviest cuts on the journals. Railroad machine shop work was not what you'd call fine work. In the steam locomotive days and when plain journal bearings were in use, it was often heavy machine work and not done to particularly tight tolerances. Another activity the railroad shops did was to "burnish" axle journals after turning. This consisted of forcing a hardened steel roller against the journal as it revolved in the lathe. Burnishing improved the surface finish and grain structure and produced a localized work-hardening. When a steam locomotive came in needing work on the "main brasses"- the plain bearings which the driving axles ran in had brass shells but were poured with babbitt- if things had gotten hot enough to melt the babbitt, chances are the journal was scored. A cut was taken on the journals and then the turned surface was burnished in the wheel lathe. This put a tremendous side load on the centers, probably more than was developed on hogging cuts on the journals or wheel tires. After the journals were turned and burnished, the brasses having been rebabbitted (or spares on the shelves) were bored to suit the new diameter.
A buddy who is retired as a freight engineer and sometime trainmaster has told me that old time railroad equipment was designed to be worked upon by "idiots" with minimal skills and minimal tools. The result is a lot of what I've seen on older rolling stock and locomotives fits this description. In the back shops in steam days, there was a schedule and work on the locomotives had to be done and gotten out in accordance with that schedule. Locomotives did not make the railroads any money when they were in the shops. It was a case of heavy duty machine tools and taking the heaviest cuts possible, rather than taking additional time with finer cuts to turn a journal or wheel tire. Maybe the 60 degree carbon steel centers were not holding up in this kind of service, so the 77 degree was tried and squeaked by (pardon the joke). This was the time of hardened carbon steel centers lubed with white lead and oil, when the "dauber" on the lathe tailstock actually was used.
