Advantage using this B&S Mill
Results 1 to 15 of 15
    Dec 2010
    Mifflintown, PA 17059
    1,956
    25
    249
    Default Advantage using this B&S Mill
    Looking at HGR from time to time to see if they have something I can use. They have a B&S Horizontal mill but the spindle and drive is mounted in a dovetail ram. what is the purpose of this arrangement?
    Used Machinery & Industrial Equipment | HGR Industrial Surplus[ATTACH=CONFIG]295306
    [/ATTACH]
    Virginia
    31,850
    7561
    10015
    Quote Originally Posted by Froneck View Post
    Looking at HGR from time to time to see if they have something I can use. They have a B&S Horizontal mill but the spindle and drive in mounted in a dovetail ram. hat is the purpose of this arrangement?
    [/ATTACH]
    HGR call it a 10" X 50". Not all that special, but..
    I suspect the way it is built gives it a wider range of tool to work positioning where large and awkward parts have to be gotten into the work zone, then reached across to get to a feature to be milled.
    Find a vintage OEM brochure, it will probably brag about that - or whatever ELSE it was as justified the design.
    Apr 2013
    Damascus, MD
    1,539
    4543
    874
    If I hadn't seen the name cast in the column, I'd have called it "Van Norman & Sharpe".
    Paolo
    Jul 2004
    Houston, TX USA
    31,025
    Never seen a DYNAMASTER - but I think that is what it says under B&S
    Listed for years '61 to '67 in serial book
    Using my x-ray vision, I see its a "empty column" design
    Virginia
    31,850
    7561
    10015
    Quote Originally Posted by johnoder View Post
    I could look it up but.. short time in the market may have had nought to do with merit.
    ISTR B&S and their Union marched out of the factory and more or less right into Hell after one of the longest-ever "detours", around that time, did they not?
    Dec 2010
    1,956
    25
    249
    Seems to me there was a particular application for this design. It does have round overarms but the support piece is missing as it often is with horizontal mills on HGR. I know production mills had movable spindles because the table had no "Y" adjustment. I've owned quite a few horizontal mills and can't think of any reason for his design.
    Jul 2004
    Houston, TX USA
    31,025
    did they not?
    Maybe so - I left RI August '63 and by then the new digs in North Kingston were well on their way - escaping finally from the century old plus filth of the sprawling Providence plant
    Apr 2004
    Riverdale, Nebraska, USA
    827
    106
    60
    Looks to have more fore/aft travel than average plus spindle carrier travel would make it more HBM-like.
    Jan 2007
    Norfolk, UK
    20,070
    15469
    15822
    I'm well out of my depth on B&S (don't shoot ), but I found this - a ''Rangemaster'' ????????????
    http://vintagemachinery.org/pubs/2185/19773.pdf
    and this http://vintagemachinery.org/pubs/2185/20060.pdf
  10. Likes 4GSR, SVE Performance, Paolo_MD, rivett608 liked this post
  11. #10
    Virginia
    31,850
    7561
    10015
    I just now did go and look it up. About ten years later than this mill went out of the catalog in '67.
    Beginning of the end was when both sides got at cross-purposes, 1977, neither ever flinched an inch in a damn-fool war to the death:
    Beginning of the end of Browne and Sharpe | WJAR
    Extract:
    Brown and Sharpe shut down its North Providence Greystone plant on Nov. 16, 1982, in the midst of a machinists' union strike that began about five years earlier.
    The "terminal" five years were not even the whole saga. Elsewhere it has been written up as one of the longest, stupidest, and most destructive industrial actions, ever, with a seventeen year run, and a major influencer on MOST New England manufacturers folding up or moving out of the reach of inflexible "seniority or death" Unions.
    Meanwhile, as with plants I have seen down-sized, then soon after shut-down, and then liquidated, not even MOVED, same reason, "hands on", (IBEW) ..the CUSTOMERS had gone elsewhere.
    Of course they would!
    Brown & Sharpe - Wikipedia
    More to the point of machines as "new" as this one, in thread?
    Wiki history sez B&S was ALREADY getting out of the general-purpose milling-machine bizness - or PLANNING and trying to do - in favour of "automatics", and from the 1950's, as much as ten years before this one appeared?
    "Be that as it may.." an era had sort of been sidelined as much out of indifference as of conflict.. as B&S had moved-on. Back to their roots in metrology, mostly.
    "Bean Counter grade" history here. If anyone still cares. I knew they SOLD Tesa goods. I had not been aware B&S OWNED Tesa, nor Leitz of Wetzlar, and a few other well-known-name "surprises":
    History of Brown & Sharpe Manufacturing Co. – FundingUniverse
    Back to the future:
    This - mini-HBM'ish? - mill might have been one of the last-ever new'ish B&S designs as far as "mostly conventional" mills go?
    Interesting if it gets a new home and is put back to making chips,, "right here, on PM".
  12. #11
    Dec 2010
    1,956
    25
    249
    I can understand using a Horizontal Mill as a mini HBM. However I had quite a few K&T mills and also seen B&S mills at HGR with rear controls. For those that are not sure what rear controls are, they are a means of operating the mill on the spindle side of the table. My K&T's had dials in thousandths to move the table UP/Down and In/Out (Y), engage the feed for both. The X axis was available on the end of the table with a means to engage the feed. Another handle was for rapid that would engage rapid travel to any axis the feed was engaged. I have seen this also on B&S mills, both were on the LH side.
    I would think that if this mill was intended to be used as a mini HMB when needed the rear controls would be provided.
  13. #12
    Virginia
    31,850
    7561
    10015
    You would be disappointed.
    It is a rule of nature that even the best of machine tool builders are never allowed to be QUITE one-hundred percent right!
    Not until humans get sorted FIRST, anyway!
  14. #13
    Apr 2020
    Ohio
    248
    158
    59
    Used Brown & Sharpe Brown & Sharpe 506-20-4 Universal Mill | HGR Industrial...
    Here’s one at HGR still with the head. I like the little crane that swings the head from the side to the front. Cool mill wish I had space for something like that, the manual makes cutting dovetails and t slots a breeze!
  15. #14
    Apr 2004
    827
    106
    60
    That HGR mill is pretty sharp! I’m coming around to the Van Norman duplex clone theory.
  16. #15
    Dec 2010
    1,956
    25
    249
    I think the Dynamaster was a later designed mill. I had one that had auto cycle and didn't like it. It had a series of switches on the X axis that would use Hydraulic power for feed. I seen other versions that used mechanical levers to operate the feed. Interesting feature that I don't know why it was designed that way but the spindle housing protruded out not flush with the vertical ways like the older versions.
