Darren McCarley
Cast Iron
- Nov 24, 2017
- DFW
Would like to get yalls input. I'm restoring an old Wade 8a lathe. (Circa 1943) I'll be running it with a VFD and 3hp motor, jack shaft and permanent belt location(s). The VFD will be used to vary the RPM. While I'm primarily interested function, I do like to keep things true to the period if possible. The image attached is a later Wade tachometer. They are nearly impossible to find and expensive when they do surface. So, what are yalls thoughts on an alternative "period correct looking" tach? I'm not afraid of hot rodding the thing to use an old airplane tach, or even old Mac truck tach.... thoughts?
First pic - Wade tach (not mine) Thanks Wade8a.com!
Second pic - my Wade 8a before refurb/clean up.
