Allen Drill Press Taper Drift Slot Question
Results 1 to 6 of 6
    Aug 2017
    Illinois
    99
    58
    30
    Default Allen Drill Press Taper Drift Slot Question
    I came into possession of what I believe to be a Chas G. Allen drill press which has been modified into more of a bench top model by omitting the lower way column and back half of the head casting.
    What I'm curious about is the slot where one would insert a drift to break loose the Morse #1 taper.
    Admittedly I have next to no experience with machinery of the vintage, but I've never seen a drift slot that was "keyhole shaped" before, only oblong slotted.
    Was this common for the era, a bit of styling by the manufacture, or is there something more to it that I'm not aware of??
    Thoughts would be most appreciated.
    Aug 2012
    California, Central Coast
    5,413
    2413
    2253
    They are still in business, I called and spoke to them a few years ago about a much bigger allen drill that I have. That one you have is a cute baby compared to mine.
  3. Likes John Strange liked this post
    Virginia
    21,175
    7561
    12358
    Quote Originally Posted by John Strange View Post
    Some drifts had a rounded rib on the "away" side.
    I'd guess those - in combination with the azure style you have - would be less prone to the raised welts that can accumulate at the upper-end of the common straight-sided, rounded-end, but same included diameter are victim to?
    IOW "Odd, but odd in a good way, not a bad way."
  5. Likes John Strange liked this post
  6. #4
    Aug 2017
    Illinois
    99
    58
    30
    Quote Originally Posted by Rob F. View Post
    Thanks for the reply. I was surprised to discover they were still in business myself as I was trying to find out info on the press.
    At that stage of the game I didn't even know if it was an Allen, I just saw one single photo of one that was similar, but at that time I also didn't realize this one had been cut down, so I was chasing windmills in trying to find a photo match.
    In my search I saw many of the MUCH larger ones, and they are impressive. considering how relentlessly heavy this little one is... I don't even want to know what some of the big boys weigh.
  7. #5
    Aug 2017
    Illinois
    99
    58
    30
    Ahh ha! Some having a rounded rib is the very info I was looking for. Thank you. It makes sense to have a more "precision" positive contact when striking something (especially a machine tool).
    I can only imagine, but I would guess this was meant as a sensitive or light duty drill? It's unusual in a good way to have all this cast iron for just a MT #1. Definitely built to last.
  8. #6
    Virginia
    21,175
    7561
    12358
    Most have the crowned back, but flushed at the sides. I meant a top rib that overhangs, much as if it were a round rod with a fin hanging down to form the wedge.
    I have a fairly comprehensive set of MT drills. Too lazy to go look. IIRC MT #1 gets up to over a 1/4"? I don't consider anything above a #1 drill as 'sensitive", though. OTOH, a(ny) MT gets you a tiny chuck or even a collet system, such as ER.
    Sigorney (P&W div of Niles) was mentioned.
    I grew up on Adolf Muehlmatt/Hamiltons, found my Electro-Mecano whilst searching for a nice one of those.
    "if I could only have ONE.." Rebuilt Clausing with the variator belt drive head. Floor model, not "benchtop", though.
    Powermatic made a workalike, too. Durable enough. But it shouted "CHEAPSKATE" right out load!
