Another interesting bench vise
Likes Likes:  0
Results 1 to 13 of 13
    Sep 2005
    West Virginia
    3,993
    426
    Default Another interesting bench vise
    Some may remember the thread I started about my Massey quick-action bench vise a while ago: http://www.practicalmachinist.com/vb...highlight=vise
    While cleaning the shop today, I found another neat vise I forgot I had.
    It was patented June 16, 1885, by George Colton of Syracuse, NY. Here's the patent: http://www.google.com/patents?id=pmB...ad=0_1#PPA3,M1
    An interesting feature (which is not shown in the patent) is the t-slot cast into the base for mounting. I'm not sure how this was originally intended to be used, but it fits a carriage bolt pretty well. A guess I had is that you were supposed to drill a hole wherever you wanted a vise, insert the carriage bolt, and quickly attach and remove the vise as needed.
    Andy
    Oct 2005
    Charlottesville, Virginia
    563
    10
    That's pretty interesting. I've always found that when most vises swivel, they no longer overhang the work bench and whatever you're holding fouls the bench top most of the time. Maybe this was the manufacturer's idea of getting around that: you could swivel the vise and extend it out a bit so the work remained free. Perhaps it may also have come with a simple slotted mounting plate to facilitate vise extension. It sure would be tempting to make one in any event.
    Cheers, Charles Morrill
    Oct 2005
    563
    10
    Andy, I should have read the patent first! I guess you are indeed missing some kind of mounting plate.
    Cheers, Charles
    Oct 2004
    SE Ohio
    907
    137
    How did you fit the vehicle into your shop?
    Feb 2004
    Harrisonburg, Va.
    100
    What you are seeing is an optical illusion. I've been in his shop, there is no room for a car.
    Bob
    Sep 2005
    West Virginia
    3,993
    426
    Charles, you will see that my vise is different from the patent drawings. The drawings show a much smaller round base that swivels on a plate and (as far as I can tell) doesn't slide in and out. The plate does allow the vise to overhang the bench, though, so it more or less accomplishes the same idea.
    Grady and Bob, I have been cleaning the shop. Got rid of some stuff, and also recently got access to the other half of the building (which increased my floor space by about 1/3). There is now just enough room for a vehicle, Subaru-sized or smaller. It's tight, but better than working outside, especially in this weather- last night was fifteen below.
    Andy
    Dec 2005
    East Palestine, Ohio
    1,191
    5
    15
    Cool
    Andy,
    Neat vise! Looks a bit like this small one i posted late last year
    Mine has jaws that are 1 11/16" wide. Other than the base the body apears to be made on the same patent.
    Mike
    Sep 2005
    West Virginia
    3,993
    426
    Mike, if you removed the clamping screw from your vise, the base would look very similar to the drawing on the first page of the patent.
    In reading the text of the patent, it is clear that Mr. Colton was trying to cover all of his bases, ie. trying to lock up as much of the patent territory as he could.
    Andy
    Oct 2004
    Iowa
    3,128
    61
    368
    Default Lmao!
    Quote Originally Posted by W4BAR View Post
    Bob
    LMAO! (I resemble that remark)
    --... ...-- de KWOD DK :-)
    May 2002
    South Central PA
    13,440
    2169
    3364
    I saw this at Cabin fever - was that you Andy?
  11. #11
    Jan 2009
    Ohio
    126
    Check these little ones out.
  12. #12
    Mar 2007
    On Elk Mountain, West Virginia, USA
    2,083
    888
    708
    Andy,
    Would the bolt-head-capturing base be suited to movable mounting on a Acorn-type platen?
    Is there room in the base for a large square head such as was used on the bolts that hold the accessories to Acorn platens, or is space only sufficient for the shallow domed head of a carriage bolt?
    john
  13. #13
    Sep 2005
    West Virginia
    3,993
    426
    Quote Originally Posted by magneticanomaly View Post
    Andy,
    john
    Hey John, good to see you here. I think there would be room for a square head bolt in there.
    Mud, that was not me, but thanks for the photo.
    Andy
