SouthBendModel34
- Feb 4, 2004
- Metuchen, NJ, USA
Recently acquired this antique W. & L. E. Gurley Wye Level, with two tripods and a faded elevation rod, mostly as a curio but I might also try to sight some levels for landscaping.
A Wye Level is an obsolete surveyor's instrument which requires that the telescope be removed from the fork and swapped end-for-end to take a back sight. (Contrast this with a Dumpy Level, where the telescope is permanently affixed to the base.)
The rectangular aluminum base is part of the carrying case. (Somebody wrote "EYE" at one end with a Kiel crayon.)
The wooden cylinder on the base carries the sun shade (which is not original) and also has some holes of different sizes that look like they were meant to carry some small tools. There is also a non-removeable piano wire protruding from this wooden cylinder.
Q1: Can anyone comment upon this cylindrical wooden accessory carrier? What am I missing?
The level vial is A-OK.
Looking through the telescope, I can bring the intact crosshairs into fine focus with the knob on the back, but thus far I have not figured out how to adjust the "distant" focus to sharpness. I would think that because the instrument has crosshairs, there must be two adjustments so that the target and the crosshairs can be simultaneously in focus.
Q2: Is the objective, which is on a slide tube, the adjustment for focusing the target?
Q3: There are four fillister head ("cheeseheaded" to our British friends) at 90 degree intervals around the telescope barrel. These have no slots, but rather traverse holes for a miniature tommy bar. I presume these are some sort of a "do not touch" adjustment, possibly for the crosshairs? Or, what?
Q4: There are fine threads at the eyepiece end. Am I correct in thinking these are for a non-essential eyecup, rather than a missing lens?
It's not in the greatest condition; there's a lot of bare brass showing where the black wrinkle paint has flaked off. But, I bought it as an educational curio, not as a museum piece.
<ON EDIT:> I'm having difficultly uploading the photos due to DSL troubles. Will try again later or tomorrow.<END EDIT:>
John Ruth
John Ruth
