Anybody know what this piece of tooling is?
Results 1 to 9 of 9
    Sep 2005
    West Virginia
    4,204
    574
    Default Anybody know what this piece of tooling is?
    The hand wheel advances a tool steel cutter, and the advance assembly is adjustable for height and tool rake. The base has cast-in 3/4" wide keys. I can't find any identifying marks, except for the numeral "3" stamped into the bronze block that advances the cutter. Thanks for any ID or ideas.
    Sent from my SM-G950U using Tapatalk
    Jul 2004
    Houston, TX USA
    31,949
    A guess might be weld bevel maker for good size pipe
    Mar 2020
    CANADA
    Quebec
    232
    382
    148
    Looks like it would work as a tool holder for turning on a horizontal mill?
    Apr 2011
    Modesto california USA
    707
    1250
    935
    Probably the tool holder from a valve refacer.. think gas engine valve.
  5. Likes rivett608, Illinoyance liked this post
    Virginia
    18,967
    7561
    11654
    Quote Originally Posted by Andy FitzGibbon View Post
    It may not exist to USE the cutting tool at all.
    The curiously light construction and modest grip, topside, for its overall mass, plus the lug on the base, suggests it aligns on the table of a Tool & Cutter grinder .. to grind a chosen COMBINATION of angles onto a cutter.... that will then be put to work ELSEWHERE.
    2CW worth of "SWAG"
  7. Likes Kjelle liked this post
  8. #6
    Mar 2006
    Vershire, Vermont
    2,625
    1840
    873
    Hm. Bill, ya might have something there.
    Looking at the bottom of the fixture, the periphery of the through hole isn't coplanar with any machined surface. So the hold down can't be tightened much without risking cracking the fixture.
  9. #7
    Jul 2010
    Virginia, USA
    3,592
    87
    705
    Maybe some kind of simple wheel dresser for a grinder?
    allan
  10. #8
    Virginia
    18,967
    7561
    11654
    Quote Originally Posted by neilho View Post
    Whole thing shouts "alignment tool" not "high stress tool" don't it?
    As to "dressing" a(ny) abrasive wheel with a sharp HCS or even HSS blade?
    "Get real!" Blade LOOSES! And rapidly so.
    Grinders exist to win that war, ever' damned time.
    If no diamond?
    "Crush" type star and rim rollers.
    Yah need those ANYWAY for salvaging wheels some fool has loaded-up with white metal or Braze if not also friggin' PLASTIC!
  11. Likes Hudson liked this post
  12. #9
    May 2011
    southern in.
    1,630
    2141
    429
    Maybe a scribing tool for an indexer operation, such as putting graduations on round parts.
    Or maybe not.
    JH
  13. Likes garyphansen liked this post
