Hello,
Just recently, I became a happy owner of an Åsbrink lathe.
Have you ever heard of it? It is one of the different swedish versions of the Southbend 9” lathe.
My lathe is the longer version which means that the bed is around 1450 mm. It was made in southern Sweden and my lathe was probably produced in late 40’s or 50’s.
Unfortunately, the previous owner has taken it apart and some of the pieces have been lost over the years.
At the moment I miss most of the parts in the headstock, only the main casting for the spindle remains.
Hopefully, there may be an option to fit Southbend parts to it, but I am not 100% sure if they will fit. There might be some need for modifications.
To start with, I will go for plain bearings, but if I can find a good solution for tapered roller bearings or angular contact ball bearings, I can get the precision and speed I wish for.
