back gear question
Likes Likes:  0
Results 1 to 3 of 3
    Mar 2019
    Michigan
    27
    6
    Default back gear question
    if i want to run this back gear, i cannot see anyway to lube it. Anyone know what to do? there are 2 lock bolts in the shaft bearing per end, but zero lube points, and i cant see any way to get lube in. 1ts my 1917 Walcott. i dont want to harm it.
    Oct 2019
    NICARAGUA
    106
    41
    A pic would help. My old leblond had a setscrew in the center of the hollow shaft between the gears for lubing it. Take out the screw, fill with oil, replace the screw.
    Jul 2004
    Houston, TX USA
    30,097
    Quote Originally Posted by Gary Main View Post
    As a last resort, disassemble, clean up a bit and put it back together with Isky cam lube or the like (hot rod slippery stuff)
    While you are at it, put in a lube hole or two if you like
    Most will have a journal on each end
    I put lube passages in these heavy 36" shaper parts that Ohio was neglectful of providing
    Attached Thumbnails Attached Thumbnails dcp_0635.jpg   dcp_0636.jpg   dcp_0641.jpg   dcp_0642.jpg   dcp_0643.jpg
