Becker 2A Jig Bore with Bridgeport head
Results 1 to 9 of 9
    Jul 2019
    Illinois
    10
    8
    9
    Default Becker 2A Jig Bore with Bridgeport head
    Today I brought home a Becker 2A jig bore. It came with a Bridgeport head ser. # R242. From what I believe I know, the head was made in 1939, Bridgeport Pattern & Model Works. The head is stationary, but the spindle housing moves up and down with the handle. No quill. It has a steep taper spindle, probably 40 degrees included angle with a 7/16 thread on the drawbar. Would the Bridgeport head have been original to the Becker Mill? The install looks factory, but I could not find anything confirming it on line. Has anybody seen or have one of these machines? And was it a partnership between Bridgeport and Becker?
  2. Likes Peter S liked this post
  3. #2
    Mar 2007
    L'Orignal, Ontario Canada
    2,088
    1732
    838
    I am thinking that the Bridgeport head is a shop made add on using the motor , v belt and pulley system to drive the original Becker spindle shown here but perhaps you are right that the the complete unit was added on .
    I don’t remember seeing one like that before.
    https://www.practicalmachinist.com/v...-bookmaker.jpg
    There is lots of Becker Information in this thread where the above was posted in case you haven’t seen it .
    Please Help Date my Becker
    There have been other Becker machines featured in threads on this forum so if you try a forum search for Becker something more may turn up.
    Jim
    Aug 2018
    Washington
    60
    7
    Don't know about the Becker, but I do know that Bridgeport sold heads a la carte for adaptation to other milling machines, and made an adapter specifically for K&T horizontal mills.
    Here's a link to one of their catalogs: Bridgeport Machines Inc. - Publication Reprints - Bridgeport Textron Attachments and Accessories for MIlling Machines | VintageMachinery.org
  5. Likes Jim Christie liked this post
  6. #4
    Jul 2019
    Illinois
    10
    8
    9
    Yep, that is what I thought as well. I will try to get a pic tonight of the head mounting, as it looks well done, an actual casting that bolts into the colummn where the flat belt system used to bolt to. Also want to put up a pic of the collet, as I still cannot identify it. I may end up making my own, but my OD grinder will not grind that much taper.
  7. Likes M.B. Naegle liked this post
  8. #5
    Feb 2011
    2,265
    1695
    968
    ^ That would by my guess is that they adapted the top half of a BP head to replace the original flat-belt drive.
  9. #6
    Jan 2019
    Virginia
    209
    142
    35
    [QUOTE=M.B. Naegle;3491154]^ That would by my guess is that they adapted the top half of a BP head to replace the original
    I thought about that too. The top half says "R" which means R head that uses R-8 collets but has no extending quill. The quill extends so, 3 choices. MT #2. B&S #7 or B#3.
    Maybe I got this backwards but if it works, it does. Somebody else did this.
    The motors are really heavy and don't ship well when attached. Sometimes it works and sometimes the whole case is cracked. Tig is the only way and we've seen that.
  10. #7
    Jul 2019
    Illinois
    10
    8
    9
    Ok, here are a couple pics of the mount. It is a casting, looks like it was made for this mill, same contour as the top of the column.
    Also, I included a pic of the collet. It is 20 degree included taper, with 7/16"-20 thread. The small end is .625", the other end has been end-user bored for 3/4" with a set screw for a Weldon flat. The endmill bore is owner modified,but the taper and the ID of the spindle are either original, or very nicely modified. I have no idea what taper this is.
  11. #8
    Jan 2019
    Virginia
    209
    142
    35
    Quote Originally Posted by T-Man 1066 View Post
    I don't own anything with a "Jarno" taper but they were used. WAG.
  12. #9
    Jul 2019
    Illinois
    10
    8
    9
    Quote Originally Posted by alum100k View Post
    Jarno taper is .6000"/foot, this is alot more. I am guessing that I will be making my own collets. This was just too cool of a machine to let go to the scrapper.
