Behold!... The Frankenmill!!!
Frank R
Stainless
Dec 18, 2009
Dearborn, Michigan
Do not look away...
Gaze upon its ugliness...
The motor, belt, and pulleys are missing. Probably making it even uglier.
A guy I know built this years ago to do light hobby machining on a small budget. He grew up around machines all his life and is quite brilliant. He told me he has one quality that many wanna-be machinists lack: patience. He is in no hurry to get the job done. He can work with lighter machines and still complete his projects.
Do not look away...
To quote one of my more resourceful Officer grads, a "Baltimoron" by heritage:
"That's about the UGLIEST thing I've seen since the hawgs ate my little brother."
Hafta add, I'd bet the lard, bacon, ham, and pork chops were still OK though.
Actually, I think it's pretty clever. Hey, little money so you have to make do sometimes. The only thing I'd question is that X/Y import drill press vice.............
The components, as far as I can tell, include:
  • An engine stand
  • An engine block
  • Two angle plates
  • A cross slide from a Logan lathe for vertical adjustment
  • An import drill press vice
  • Some home made brackets for the motor mount
  • A head from a Sherline-like lathe or mill, but with re-built arbor.
  • A drafting lamp
Somewhere I seen a book that had plans on how to convert an old I6 or large 4cyl block into a make shift horizontal mill. Regrettably, I also passed up an old (1948 I think) copy of popular mechanics that was a manual on how to make a drill press from a washing machine motor and a ford T or A rear axle, using parts from a Ford B transmission.
