Don't make your problem someone else's by pitching that crap in your household trash.
Actually, possibly the best place for it is household trash.
Burning of household trash is essentially a "concentration" process. The 100 percent trash that goes into the process becomes after burning 10 percent "concentrates" of "bad actors." Maintenance on waste burning boilers (welding, cleaning) is usually done in full haz-mat suits because of the health risk.
Here is the trash stream process in most locations:
1. Streetside pickup.
2. Separation of "consumer containers."
3. Trucking remainder to incinerator.
4. Burning under EPA control (7 pollutants to Federal Emission Standard)
5. Ash remaining "mined" for non-Federal inclusion including, copper, brass, steel & iron, even lead that finds its way into the ashpit (not vaporized.)
6. Remainder "stockpiled."
For the beryllium, the stockpiling is the important part. A large outdoor pile is created under which are three layers of rubber. The interstice between the rubbers is "monitored" and any drain from or intrusion of liquid from the pile above is removed, treated, filtered, and released to the environment meeting Federal Emission Standards. Most of the liquid removed is rainwater which water, as one of the most perfect of solutes, will eventually dissolve and carry away the bad actors in the pile.
Eventually (hundreds of years) the pile will remain (90 percent silica) and the bad actors will be concentrated by water treatment, and further isolated from human contact.
Everyone talks about the hazard of radioactive waste - the cost of storage of non-radioactive haz-mat waste FAR exceeds the cost of waste nuclear storage - and that includes the 24/7/365 guards. The trash burning stockpile will remain a stockpile for WELL into the foreseeable future and will require continuous water treatment of rain that falls on the pile.
But as a place to put trace amounts of beryllium, it makes sense.
Around here, everyone is encouraged to put their waste Mercury containing batteries in the trash. Mercury is one of those 7 Federal Emission Controls that trash burners must meet.
Surprisingly, one of the most difficult materials for Trash Burners to burn is gypsum sheet-rock (construction waste.) The gypsum releases VAST QUANTITIES of Nitrous Oxides (Another Federal Emission Limit) in burning. If I knew construction waste including sheet-rock was part of my shift quota of fuel, I would encourage the Tipping Floor to isolate and "measure out" any sheet-rock.
The solution to pollution IS dilution. A fact totally forgotten in the disposal of waste nuclear materials. (Dare I say this?)
Joe in NH
Former Trash Burning Powerplant Control Room Operator
