Big, Big Wisconsin T-Head engine - Page 8
Page 8 of 19 FirstFirst ... 67891018 ... LastLast
Results 141 to 160 of 373
  1. #141
    Jul 2008
    Asheville, NC
    2,426
    1197
    1137
    Quote Originally Posted by lathehand View Post
    Terry: Thanks for the additonal photos and commentary. Exactly what I wanted to see. Both your work, pics and explanation are well done and I for one enjoy all of your posts. Carl
    Amen to the above. Thanks for your efforts.
    Paul
  2. #142
    Sep 2009
    Maine USA
    377
    19
    792
    After what seems like ages I can finally check-off (almost) a complete assembly. If you recall way back in post #134 I had payed a visit to the Odd Duck Foundry and Peter had cast the pieces for the upper water manifold (Parts No. A18A, A19A, A20A & A32A) Well here they are after machining and polishing - Over 40 inches of gleaming brass and bronze. I still have a few details to complete - fabricating a couple of high crown bolts and removing the plating from the nuts. The pieces will be joined together with 1-1/2" radiator hose. Currently waiting to order the hose (period correct wrapped red hose) and the proper wire clamps. Should look real nice!
    Special thanks to Peter Grant of Odd Duck Foundry for the "Foundry 101" lessons and letting me get in the way.
    I have quite a sense of pride in ths assembly having developed it from measurement to drawings to pattens to finished casting.
  3. #143
    Sep 2009
    Maine USA
    377
    19
    792
    Oh...that odd set of six cylinder heads in the foreground....thats another project...an air cooled series 135 engine from a 1929 Franklin. Its in rough shape - two stuck pistons, two broken pistons, lots of stuck valves....
  4. #144
    Sep 2009
    Maine USA
    377
    19
    792
    This weeks adventure was fabrication of a tool for bending the 12 Valve Spring Cover Clamps (Part No. 034X)
    I know, I know I should have used steel but I didn't have any decent pieces available but I did have this box of misc. brass that a friend gave me and it was close at hand..However I did recycle an old valve stem from the beast for the handle and pins.
    To bend the eylets I will use a simple two pin setup. Now Iam just waiting for the order of spring steel to come in!
    Anyway here is the result:
  5. #145
    Aug 2012
    Pittsburg, KS
    1,241
    125
    554
    Terry, it looks good, it has been awhile since i bent any spring steel so i may be off here, is there some compensation built into your fixture so the result is the size you want? i hope you get what i am asking.
    also, i don't remember what you where going to do with it when you get it running. You could poke a hole in the ground for some natural gas and run a generator with it, make it earn a little back.
    jason
  6. #146
    Nov 2004
    107
    271
    25
    Terry:
    Thanks for keeping us updated. This thread has been interesting, and more than a little inspiring.
    At least with the Franklin engine you won't have to worry about fab'ing any plumbing for coolant!
    Cheers,
    Brian
  7. #147
    Sep 2009
    Maine USA
    377
    19
    792
    Today I put the spring clip bender tool to good use. After working to get a technique somewhat perfected I was able to turn a few out.
    Only nine more to go!
  8. #148
    Nov 2007
    Hawkinsville, Texas
    593
    20
    32
    Terry,
    Your project is coming right along. What a huge undertaking. It looks good. I don"t have any experience working with spring steel. Can you tell me more about it? You buy it in lengths & form it and it holds the shape? Do you have to do anything else to get it to retain the intended shape?
    toolles
  9. #149
    Sep 2009
    Maine USA
    377
    19
    792
    Hello Toolles,
    Until the other day I had never worked with it either!
    Anyway, I bought mine from McMaster-Carr - they offer it in strip form in varying widths and thickness. They offer 1074 and 1075 in rolls of varying lengths. I opted for the tempered scaleless blue steel. In hindsight I should of bought the un-tempered general purpose steel.
    To overcome springback I made my bender outfit smaller than the finished piece - however it wasn't nearly enough. To form these I had to anneal (heat & quenched) the steel then I could form it very easily. Now you know why I shouldn't have gotten the tempered stuff) Once formed I wired the ends together to hold the shape and heat treated (i.e. heated and let cool slowly) Not sure if thats the proper way but they held thier shape-though they did oval a bit - and have tons of spring and fit very well.
    There is great website on forming springs. Mostly coil springs - lot of good info. How to Make Springs
    Anyway, I hope this helps
  10. #150
    Nov 2007
    Hawkinsville, Texas
    593
    20
    32
    Thanks Terry for the link. I've got a little project where I need to make a coil spring and I was wondering how to go about it. I appreciate being able to read about someone else doing it before I take it on. Maybe I can flatten out the learning curve a bit.
    Les
  11. #151
    Aug 2012
    Pittsburg, KS
    1,241
    125
    554
    I ran across this on another site, if you watch at 4:31 or so, there is a shot of a Lombard running; From stump to ship: A 1930 logging film - YouTube!
    Jason
  12. Likes baldwin liked this post
  13. #152
    Sep 2009
    Maine USA
    377
    19
    792
    Today we pressed in the new valve guides and started removing the broken studs for the lower water manifold.
    Moving slow but forward!
  14. #153
    Nov 2010
    Vermont
    36
    34
    7
    Love your press Terry!
  15. #154
    Sep 2009
    Maine USA
    377
    19
    792
    i wish that press was mine! I had to borrow it for the day!
  16. #155
    Sep 2009
    Maine USA
    377
    19
    792
  17. #156
    Nov 2010
    Vermont
    36
    34
    7
    Thank you Terry, and a pleasant and happy holiday season to you and yours!
  18. #157
    Dec 2009
    South Yorkshire, England.
    367
    562
    28
    Merry Christmas Terry, but I bet I'm not the only one who was dismayed that your post wasn't about the engine restoration!
    Steve
  19. #158
    Nov 2012
    New England, USA
    376
    6
    310
    Terry, Nice card and photo.....Do you have anymore Lombard or steam powered tractor photos to share?? Happy Holidays
  20. #159
    May 2002
    Auckland, New Zealand
    4,459
    1662
    465
    Quote Originally Posted by t-head View Post
    Terry.....Do you have anymore Lombard or steam powered tractor photos to share??
    Is the Pope Catholic?
    Apologies for yet another post not featuring a Big Old Wisconsin T-Head Engine.
    To make amends and provide a holiday "fill-in", here is a big (225hp), old (c.1918) engine being brought back to life not far from here.
    Four valve engine, exhaust stacks go straight up! Inlet valve cages from first cylinder shown removed. Bore & Stroke: 6 3/4" & 7 1/2".
    It is not a Wisconsin and not American, no more details in this thread though.
    exhaust-side-2-red.jpgno-6-cylinder-valve-cages-removed.-2-red.jpginlet-valve-cages-no-6-cylinder-2-red.jpginlet-valve-cages-no-6-cylinder-1-red.jpg
  21. Likes SouthBendModel34 liked this post
  22. #160
    Sep 2009
    Maine USA
    377
    19
    792
    Hello Folks! I hope you all had a great Christmas. Things have been slow in the shop which is typical for me this time of year but I have
    made a bit more progress.
    t-head
    David, I have a collection with several hundred photos involving Steam and gasoline Lombards as well as some of his early 1899 steam car
    and a bit of old film too which I am more than willing to share with the readers of "THE OLD MOTOR" PM me and I will get you my E-mail address.
    Peter, That looks like an amazing project! Iam not even going to venture a guess as to what it is! Please keep us posted.
    Ok, on to the latest progress.... I finished the pattern for part No. A29A (Lower Water Manifold - Front Section) I had feared doing this piece from the start of the project but in the end it was fairly straight forward.
    Like the pattern for Part No. A28A (the center water manifold piece) I had to fabricate a follower and a four part pattern. I made the straight section which connects to the extension off of the water pump
    extra, extra long so I could hold it in the chuck while I turn the outside to diameter and cut the threads for the big coupling nut. Once the turning operations are complete I can part
    it to the correct length and counter-bore. Currently I am working on the core boxs. Once these are complete it will be time to tackle the last water fitting! Yahoo!
    And.... what the original fitting looked like
  23. Likes Peter S liked this post
