Hello again with the questions. I have had this boring bar holder for a few years and I am now going to put it to use after a failed effort due to a small one not being rigid enough for the job. No name on this holder. It will take a 1 3/8 inch bar. Only marking is the cast number 212. No name as per usual. Very strong holder of American manufacture I would think. Any help and guesses will be a great. Thanks, Ted
Only "guess" I can offer is you don't have any significant boring to do. The lathe and compound UNDER it, it may as well be a McCormack-Deering hay rake.
Research and consider this - I surely ain't the "inventor" of it. Not by 150 years or more.:
- pull the compound rest.
- find or fab a solid monolith Cast Iron or steel "tower".
- mount it directly to the top of the cross slide. Center it.
- Drill the cross for a taper pin you can insert and remove by hand.
- Now drill the tower block from the headstock. Bore it HS to TS center, "line bore" style.
- A bore of 2" that can take recycled turret lathe bushings is good.
- split it for clamping bolts if you forgot to make it two-piece to begin with.
Look around. Folks even sell these, ready-made. Or at least they do/did in England? See "Gibralter".
Now:
Taper-pin IN, you are dead-nuts on-center for drilling with the carriage. No "measuring" required.
Taper-pin OUT you are set up to use boring bars up to two inches with the minimal deflection the cross slide (carriage and bed..) can deliver, CLAMPED if/as/when need be between cutting passes.
Compound is still "elsewhere".
A compound rest only ever WAS an add-on accessory many a
serious lathe never saw the arse of in 100 years of hard work.
Not even for single-point threading, given the alternative to a Gibralter-type bar holder is a 4-Way mounted directly to the topslide.
Compounds are for cutting tapers too short and steep for TS setover or a taper attachment.
Not a lot more than that. Rest of the time their primary job is to add slop, flex, and vibration.
2CW
