Goat Marshall
Cast Iron
- May 11, 2006
- Michigan, USA, the World
I just finished mounting the countershaft, handles and belts for this little Boynton shaper that I got from Irby Jones (who posts here frequently) last fall. This was made in the 1870's, before Boynton and Plummer merged in 1880. The table is moved up and down by hand and locked into position; the head with the cutter moves across the work. I still need to anchor it to the floor, and then I can run it. I'll take a video and post a link here when I do.
My plan is to use this for cutting through the surface scale on dies after they're forged. Single point tools are nice for that, especially since the alloy I mostly use is 5160 and is not always perfectly annealed (being done by a blacksmith and all). Most of my dies for the press are about 3 1/2" square, so this shaper should be just right for that and a lot faster than my belt shifting 24" Smith and Mills. I need only light cuts for that, after all.
Joel
Joel
