Bradford Metalmaster - Page 7
Page 7 of 7 FirstFirst ... 567
Results 121 to 137 of 137
  1. #121
    Nov 2020
    Alabama
    78
    28
    41
    Got an AMEC spade drill and did some boring. Took out 8" without much fuss. Put together a coolant setup with an aquarium pump. Worked pretty well we'll see how it holds up.
  2. Likes Greg Menke liked this post
  3. #122
    Feb 2004
    Baltimore, MD, USA
    4,312
    469
    738
    Wall has coolant racing stripe == work getting done
  4. #123
    Mar 2020
    CANADA
    Quebec
    258
    426
    158
    Quote Originally Posted by Greg Menke View Post
    Same could be said for the operator!
  5. Likes Greg Menke liked this post
  6. #124
    Feb 2004
    Baltimore, MD, USA
    4,312
    469
    738
    Yes! One quickly learns to not stand facing the side of the chuck
  7. Likes FJsapper liked this post
  8. #125
    Mar 2020
    CANADA
    Quebec
    258
    426
    158
    Aw,, come on. Who HASN'T stood in front of a lathe when a freshly lubed chuck is spun up for the first time??? [You get extra points if you can even taste it!]
  9. #126
    Mar 2016
    Alabama
    370
    423
    108
    Quote Originally Posted by dundeeshopnut View Post
    How about when you're boring a small hole at high speed with coolant, and you think you're ok, until it overtops the shoulder in your part an hits your 12" chuck...
    I wiped off the lightbults and window, left the rest.
  10. Likes dundeeshopnut, Greg Menke liked this post
  11. #127
    Feb 2004
    Baltimore, MD, USA
    4,312
    469
    738
    Chips and oil all over for the win boys! even inside the safety glasses...
  12. #128
    Nov 2020
    Alabama
    78
    28
    41
    TouchDRO and glass scales Installed. Made a huge difference! A few things to clean up install wise. I wasnt too crazy about the cross slide placement but for the time being it should be fine.
  13. #129
    Feb 2004
    Baltimore, MD, USA
    4,312
    469
    738
    I really like the coolant gutter around the top of the apron, not present on my ATW, they rely on the large chip tray for drainage back to the sump. I suppose you'd need a lot of flood splashing around for it to be useful?
  14. #130
    Nov 2020
    Alabama
    78
    28
    41
    Well ive been making a little money with the old gal. Not much...but enough that my wife hasn't complained about me tooling around in the garage anymore.
    I've been working with 17-4 stainless mostly. My spade drill gets through it with a little fuss but overall is getting the job done. I wish i could get a carbide blade for it. The HSS inserts dont seem to last too long without touching up. Im getting like 3' bored through 1.5" stock before i need to switch out.
    I picked up a 6 jaw to work with thinner tubing. Just a cheapo chinese model. It seems to keep .001" which is nice. Im considering putting 4 screws around the OD to make a ghetto set-tru of sorts. For right now its good enough.
    I wanted a boring bar that could get me 8" of depth. Instead of dropping big money on a finished bar i was able to find two .78"x13" blank carbide shanks on ebay. I was able to grind the profile into something resembling a useful shape. So far so good! Seems to take .015" accurate passes which i will take as a win in my book! I may try to figure out how to graft an indexable head over the outside of it. For now its "good enough."
    Edit*
    Lets see if those picture links work
  15. #131
    Feb 2004
    Baltimore, MD, USA
    4,312
    469
    738
    Big fan of the thru tool coolant, I've been using a couple thru coolant boring bars recently. Works a lot better than trying to tease the coolant nozzle around to get the jet into the workpiece and the chip flushing is effective. Your emulsion looks a lot less messy than the cutting oil I'm using.. it works great but being a lot more viscous it tends to throw blobs off the workpiece.
  16. Likes FJsapper liked this post
  17. #132
    Mar 2016
    Alabama
    370
    423
    108
    I am unable to see the pictures. Anyone else?
  18. Likes dundeeshopnut liked this post
  19. #133
    Jan 2012
    west virginia
    145
    11
    21
    your machine came out real nice, looks just like mine only shorter!dsc00481.jpg
  20. Likes Greg Menke, FJsapper liked this post
  21. #134
    Nov 2020
    Alabama
    78
    28
    41
    Quote Originally Posted by djones3158 View Post
    You were my inspiration! That and when i got the ugly green paint off i had a dark gray like yours underneath.
    Do you have the same crazy high TPI feeds on your machine? Mine goes to 368tpi!
  22. #135
    Nov 2020
    Alabama
    78
    28
    41
    I was thinking i might try making mine a little more....oily...and less watery. I think this stuff is way more of a coolant than a cutting aid. Could just be the concentration. Im sure there is a better product out there i just havent looked very hard.
  23. Likes Greg Menke liked this post
  24. #136
    Feb 2004
    Baltimore, MD, USA
    4,312
    469
    738
    I spent a while thinking of that tradeoff also. I came down on cutting oil due to the relatively light duty, and convienence of not needing to maintain coolant- tramp oil or rust isn't a concern for instance.
    It is harder to clean up after though, takes a while to drain off the ways back to the sump. I'm not sure of the tradeoff of a racing stripe laid up your chest and glasses between emulsion vs cutting oil
    But maybe you're thinking of a thicker emulsion, not cutting oil...
  25. #137
    Jan 2012
    west virginia
    145
    11
    21
    Yeah mine has the same! Mine was actually green in the beginning I think. I wanted a dark grey so I mixed black and white together to get the grey I have. the handles were 1985 Olds Cutlass left over from a car I painted years ago. My machine may be for sale in the future as I am getting to the age I don't want to leave it for my son to deal with. Going to be hard to do as this belonged to my Dad. If anyone reading this has an interest I will say I don't get on here every week. I'm not ready to price it yet, just trying to think ahead a little.
  26. Likes FJsapper liked this post
