Bringin' Home A Springfield 16" Lathe
Page 1 of 6 123 ... LastLast
Results 1 to 20 of 104
    Dec 2016
    Washington
    315
    89
    89
    Default Bringin' Home A Springfield 16" Lathe
    ...gonna cut some steel. This looks like it has a good bit of life in it still. < .002" carriage drop over 50" says the flat tailstock rail. Good gears. Serial # 1094. Taper attachment. Lots of tooling. Yippee!
    Attached Thumbnails Attached Thumbnails 20161226_085106.jpg   20161221_180317.jpg
  2. Likes Mike C., climb-101, Jachin liked this post
  3. #2
    Nov 2007
    marysville ohio
    9,269
    2647
    6129
    Quote Originally Posted by morestainless View Post
    Looks good, not much wear for for it's age. Lots of broken handles, has it done a face plant? A member here has done beautiful job rebuilding his springfield, may be able to help with yours.
    Dec 2016
    Washington
    315
    89
    89
    I'd say no to a face plant, rather, bumps and falling objects. Too many handles are intact. Minimal wear - no V way ridge. The relocation requires disassembly. Pulling head stock and bed today. I have studied Doc's excellent work on his Springfield.
    Dec 2016
    Washington
    315
    89
    89
    ...seems to be complete, with the exception this "doodad", which is missing: http://www.docsmachine.com/projects/...eld/sp050.html. I guess I'll have to try making one.
    Jan 2005
    Southcentral, AK
    2,585
    1663
    Nice. It's surprisingly close to mine, except you seem to have a slightly older style headstock.
    Take lots of pictures of the disassembly- not only for your own reference later, but I'd also like to see some of them. Mine, we suspect, had been partially dismantled before being sold for scrap, and was then reassembled/resurrected. There's more than a few little things on it I've wondered if they were original or some latter shopmade fix.
    Quick notes: The oil line from the apron pump up to the carriage is broken, and you appear to have the leadscrew reverse on the apron and a threading dial, which I find kind of curious. If or when you take the carriage off, I'd be very curious to know if you have both miter gears for the carriage drive crown gear. (Due to the LSR, mine only had one gear, the selector lever appears to have been blocked off at the factory.)
    Is it a threaded chuck or an L-taper mount?
    Doc.
  7. Likes morestainless liked this post
  8. #6
    Jan 2005
    Southcentral, AK
    2,585
    1663
    -I can get you some measurements off of mine. I'd presume they were essentially identical.
    Doc.
  9. Likes morestainless liked this post
  10. #7
    Dec 2016
    Washington
    315
    89
    89
    Quote Originally Posted by DocsMachine View Post
    Doc.
    Thanks Doc. That would be a big help. I can do 4 axis machining on my mill so fabricating a new one will just be a matter of having the right dims, ect..
    I was wondering why there was no oil pressure build up when cranking the handle with the rack pinion pulled out.
    I'll get some picts of the apron gearing today.
  11. #8
    Sep 2005
    il.
    6,632
    30
    1213
    I like Springfield's
    very robust
  12. Likes morestainless liked this post
  13. #9
    Dec 2016
    Washington
    315
    89
    89
    Sorry, the apron pict is blurry.
    Is that the L taper chuck mount? I had some leather between the chain and the spindle taper when lifting.
    I was just barely able to get to the face side bed bolts, through the oil sump openings (up to the elbow) and equally able to hold the socket wrench, with all the goo that was in there. No metal fragments, but the right compartment was partially filled with grease and there was some water or coolant in it. No sign of rust that I noticed, but I'll check more thoroughly tomorrow. Neat the way the sump overflow separates impurities.
    20161230_173255.jpg20161231_101839.jpg20161231_150949.jpg20161231_150911.jpg20161231_150928.jpg
  14. Likes Sachmanram, Jachin liked this post
  15. #10
    May 2011
    Toledo, oHIo
    298
    512
    104
    Looks like a stout rig. Good Ohio made IRON!
  16. #11
    Jan 2008
    southern il
    870
    145
    296
    While never having used one, it sure seems like I would be very pleased to possess one............they look very capable.
  17. Likes morestainless liked this post
  18. #12
    Jan 2005
    Southcentral, AK
    2,585
    1663
    I know mine's hell-for-stout. It might not be in the same class as a big Pacemaker or DSG, but it's big, heavy and has lots of iron where it counts.
    To the OP: Yep, that looks like an L-1 spindle nose, pretty much identical to mine. If you ever find out for sure what the inner taper is, I'd be curious to know that, too. Mine's not necessarily any Morse I've been able to determine, and kind of buggered which leads to to think somebody may have tried to rebore it.
    You do in fact have both miter gears on the carriage drive, which is interesting. What's also interesting is that somebody appears to have liberally greased the carriage gears- possibly due to the failure of the apron oil pump?
    Apart from the difference in the headstock, it appears basically identical to mine.
    Doc.
  19. Likes morestainless liked this post
  20. #13
    Oct 2009
    Oregon
    4,094
    4391
    2056
    Doc.
    spindle tapers are usually Jarno on old lathes.
  21. Likes morestainless liked this post
  22. #14
    Nov 2004
    Birmingham, AL
    13,205
    6563
    2545
    These always remind me of a cross between an L&S and a Monarch, which is NOT a bad thing.
  23. Likes old_dave, morestainless liked this post
  24. #15
    Dec 2016
    Washington
    315
    89
    89
    Minor surface rust spots on some gears. Recommendations?
    Attached Thumbnails Attached Thumbnails 20170102_120038-0-.jpg   20170102_120058.jpg   20170102_120113.jpg   20170102_120147.jpg
  25. #16
    Dec 2016
    Washington
    315
    89
    89
    5hp single phase 230v motor.
  26. #17
    Dec 2016
    Washington
    315
    89
    89
    Gunk in the sumps...including some metal fragments.
  27. #18
    Dec 2016
    Washington
    315
    89
    89
    ...clearer picture of the apron gears.
  28. #19
    Oct 2009
    Oregon
    4,094
    4391
    2056
    Dose it have a clutched reverse?
  29. #20
    Dec 2016
    Washington
    315
    89
    89
    The taper attachment. I have the sliding piece too.
