Bringin' Home A Springfield 16" Lathe - Page 5
Page 5 of 6 FirstFirst ... 3456 LastLast
Results 81 to 100 of 104
  1. #81
    Dec 2016
    Washington
    315
    89
    89
    ...a little brushing to do on this motor housing side still.
  2. #82
    Dec 2016
    Washington
    315
    89
    89
    ...love the waxed look. Slow, but steady progress.
    Attached Thumbnails Attached Thumbnails 20170326_143923.jpg   20170412_143152.jpg
  3. #83
    Dec 2016
    Washington
    315
    89
    89
    ...more bare/waxed iron. It's amazing how much moisture comes out of the iron when you heat it up a little.
  4. #84
    May 2011
    Toledo, oHIo
    298
    512
    104
    Moisture doesn't come out of the iron......
  5. #85
    Dec 2016
    Washington
    315
    89
    89
    Quote Originally Posted by JBoogie View Post
    It is my understanding that bare iron (metals) absorb gases, including water vapor. Before waxing, the surface must be heated with a torch to drive out the moisture. That is obviously what is happening.
  6. #86
    May 2011
    Toledo, oHIo
    298
    512
    104
    That must be what's happening when I open a cold beer on a hot humid day.
  7. Likes moonlight machine, Garwood liked this post
  8. #87
    Dec 2016
    Washington
    315
    89
    89
    Ha, ha. Well, regardless, I like applying the wax to hot, dry iron. Going to look gorgeous I think.
  9. #88
    Aug 2007
    5,202
    1141
    1022
    Quote Originally Posted by morestainless View Post
    The single phase motor is CW/CCW capable, so spindle reverse is only a matter of switch wiring/position. My single phase Logan has a 3 position rotary switch providing spindle reverse. Nice that the 12" L-1 chuck won't go spinning off the spindle nose in reverse, like the threaded 5" Logan chuck likes to do.
    You can use a lock nut on the spindle, behind the clutch to prevent that. A 1/8" - 1/4" thick lock nut would probably work fine.
  10. Likes morestainless liked this post
  11. #89
    Sep 2007
    Cairns, Qld, Australia
    2,781
    866
    749
    You get water vapour from the combustion of blowtorch gas condensing on the iron surface initially until it warms up and drives it off again. You'll see little, if any condense on the iron surface using an electric hot air gun.
  12. Likes JBoogie, morestainless, Garwood liked this post
  13. #90
    Jul 2006
    Australia (Hobart)
    3,538
    561
    2676
    To paraphrase Einstein, 'For every phenomenon there is an explanation which is simple, obvious and wrong'.
    The water vapour most definitely is not coming out of the iron.
    PDW
  14. Likes JBoogie, moonlight machine, Garwood liked this post
  15. #91
    Dec 2016
    Washington
    315
    89
    89
    ...starting to look like a lathe.
  16. #92
    Dec 2016
    Washington
    315
    89
    89
    Cleaned up the carriage, installing 4 new Bijur FKA-0 control units and a new oil line. The pump works great now. Have to keep something on the floor to catch all the gear lube drip. My Dad (88) is having a time with the needle scaler.
  17. #93
    Dec 2016
    Washington
    315
    89
    89
    With 6 gallons of Casterol AW 68 anti-wear hydraulic oil and ample Vacuoline 1409 it was ready for the first power on test. I traded the old 5hp single phase motor for a new 5hp three phase motor and run that off a 5 hp, non derated, VFD at 60hz. Smooth shifting and operation through all speeds, with the exception of the large idler gear between the head stock dog clutch shaft and the quick change gearbox, which had some less than perfect teeth repair done that is a bit noisy. Something to eventually fix. The test cuts in mild steel had "good bearings" smooth surface finish. Yeah!
  18. Likes Paolo_MD liked this post
  19. #94
    Aug 2007
    5,202
    1141
    1022
    Lathe is starting to look nice!
    Can you give me an idea on what a 5HP VFD costs ? Does it go from single to three phase ?
    When I looked in the past, they were really pricey. I'd like to get one for my lathe, short of buying a Phase Perfect.
  20. #95
    Dec 2016
    Washington
    315
    89
    89
    Thanks.
    I paid $146.00 for the VFD + $50 shipping, from China. I'm putting 1ph 230v in and getting 3ph out. No issues. Some noise with CF at 2khz but quiet at 4khz. Seller with 100% + rating. )l
    All Categories
  21. #96
    Dec 2016
    Washington
    315
    89
    89
    Lead screw I made for the taper attachment adjustment.
  22. #97
    Dec 2016
    Washington
    315
    89
    89
    Added small hand wheel. Still need a cross slide screw cover.
  23. #98
    Dec 2016
    Washington
    315
    89
    89
    Need to finish up the foot pads. They work good.
  24. #99
    Dec 2016
    Washington
    315
    89
    89
    Test cut video. Very smooth finish. I'll do some measuring after levelling.
    https://m.youtube.com/watch?v=paxTq7FV4pA
  25. #100
    Oct 2006
    Norfolk, UK
    820
    806
    327
    Lucky for you that the vendor allowed you to strip the machine down in their works. A couple of years back I and Mac wanted to rescue a very similar size Lang in Wishaw,but the owners were so unhelpful that it went for scrap.
  26. Likes morestainless liked this post
