Can anyone identify the manufacturer or brand of these switches?
Results 1 to 14 of 14
    GERMANY
    3,036
    1972
    1114
    Default Can anyone identify the manufacturer or brand of these switches?
    I need to add an additional control switch to my 1960s-era Studer grinder (power on/off for an internal grinding spindle). I'd like to match the existing style if possible. Can anyone identify the manufacturer or brand of these switches? All I really need is the red bakelite or plastic lever, since I could easily fit that to a modern switch
    Mar 2018
    Oregon
    16
    If you pull the the switch out I frequently see the Id on the post end. On yours it will be on the end between the switch body and the handle.
    Kelly
    GERMANY
    3,036
    1972
    1114
    Quote Originally Posted by kelly.s View Post
    Kelly
    I looked there but did not see any marking. But I think I'll remove one switch completely and study it closely from all sides. Maybe there will be some identifying markings or symbols that I missed.
    Meanwhile I've gotten one PM from another member here, who says that the switch might come from Ghielmetti AG.
    Virginia
    31,239
    7561
    9808
    Quote Originally Posted by ballen View Post
    Looks like one that came in the door on my 1951/52 or thereabouts Alzmetall DP.
    Didn't worry about the source. Replaced it with a present-day US made one and moved-on.
    You might do the same with "current" European goods? Handle selection should have options.
    Even my new US one uses an IEC / ISO ... wotever (I GUESS) 5 mm square actuating shaft.
    And you don't see the modern switch back of the panel anyway.
    Mar 2007
    L'Orignal, Ontario Canada
    2,180
    1996
    896
    The other switch on your machine lower down looks like some of the Klockner Moeller switches that are on some of my machines.
    https://www.amazon.com/Klockner-Moel.../dp/B074KGNR8D
    MOLLER KLOCKNER T1-2-142 Nockenschalter Motorschutzschalter Hauptschalter 16A - EUR 35,99 | PicClick DE
    Perhaps a search through some of the used switches on Ebay may turn up a used one with a handle like yours .
    I don’t recall seeing many like yours anywhere in Canada.
    If you didn’t mind going to the trouble you might be able to get someone to scan one of your existing handles and have one 3D printed and put it on what ever other switch that works that would be unseen behind the panel.
    I think I would be checking Ebay and my local junk collectors before I went to the extreme of printing one but maybe printing is easy enough if you know someone with a scanner , printer and material easily available .
    Virginia
    31,239
    7561
    9808
    Quote Originally Posted by Jim Christie View Post
    MOST of the knobs and handles sold the last 80 years are still stock items from the molders who supply them to the switch makers. Google will easily find you distributors for some that match 1920's devices or my 1970's Marantz gear.
    Human hand as operates them hasn't changed all that much, regardless of the switch, other end of the shaft under the knobs, dials, and levers.
    Can't find "perfect" match in shape and colour for the newly-added odd-man out?
    Put MATCHING, ALL new knobs or levers on ALL the actuators to the switches, old or new, alike.
    Jul 2011
    East Yorkshire UK
    408
    869
    311
    Can you post a pic of the front of the control knob/handle, is there a logo in the centre/ Could be Grundfos?
  8. Likes Jim Christie liked this post
  9. #8
    Aug 2004
    ventura,ca.usa
    450
    92
    would casting your own be an option? YouTube Jim
  10. Likes Jim Christie liked this post
  11. #9
    GERMANY
    3,036
    1972
    1114
    Quote Originally Posted by hermetic View Post
    Here you are. The logo seems to be the only identifying mark anywhere on the switch. Do you recognize it?
    I've searched Ebay and a few other German/Swiss sites but not turned up anything that matches. If I could just identify the manufacturer I think it might get easier to find one.
  12. #10
    GERMANY
    3,036
    1972
    1114
    Quote Originally Posted by jmm03 View Post
    Yes, though following Thermite's reasoning I would have to make four in order to get the color to match. I am still hoping to locate one in someone's drawer of cast-offs.
  13. #11
    Apr 2015
    AUSTRALIA
    728
    37
    164
    the request for new switches has been on pm before here is a contact that was mentioned who makes switches.
    American Solenoid, Brunswick, NJ Could probably build you a new switch. They make special switches for me. Talk to Chris Meminger
    here i think this is there business address and phone check it out.
    American Solenoid Co Inc 760 New Brunswick Rd Somerset, NJ Switches-Electric-Manufacturers - MapQuest
  14. #12
    GERMANY
    3,036
    1972
    1114
    Quote Originally Posted by Street View Post
    the request for new switches has been on pm before...
    Thank you for the link to American Solenoid, but I already have a perfectly suitable switch. I just need the red bakelite lever.
  15. #13
    GERMANY
    3,036
    1972
    1114
    Well this thread has a happy ending. First of all, Jens down under was right. Look at the logo in the corner of this switch plate. It's the same as on my red lever:
    That thing that looks like a circular arrow is actually a stylised letter G. Unfortunately the PM picture has lost a lot of resolution, but in the original you can read "Ghielmetti" on the side of the switch.
    Second bit of good news is that a Hispano Suiza Hss143 from a half-century ago used these on the coolant pump:
    A really nice guy in the Netherlands is sending me one
  16. #14
    GERMANY
    3,036
    1972
    1114
    The switch itself is unusual because the shaft is not centered on the switch plate, but is below center. Ghielmetti wrote that they have not manufactured compatible switches for more than 3 decades. So I had to make a replacement myself. Since these switches were used in Schaublin and Hispano-Suiza machines, I thought I would post a few photos of my solution, which uses a small standard rotary switch, a bit of aluminium extrusion, and a steel part that I turned and then milled a slot into. This is easy because I just need to turn on/off a single phase 2A 230VAC load.
    Last thing I need is to get a switch plate made. This is glossy black anodized aluminium (0.5mm) with the numbers milled into the surface. Note that the people who engraved this assumed that the switch rotation axis was in the center of the plate, not 12mm below center!
  17. Likes Jim Christie liked this post
