Thanks Kevin,
The belting from the drive pulley on the motor to the drive pulley on then line shaft is a 3” wide 3 ply canvas belt. It’s about 10’ or so center to center. I’ve shortened it twice now and it appears to be holding there. The same 3” 3 plys are running from the line shaft to each counter shaft and they don’t seem to have much trouble either. It’s the 1-1/2” 3 ply belts going from the counter shafts to the machines that seem to loosen and slip the most. Granted all of this is new so maybe they just need a few shortenings and they will be good?
Also is there some kind of gripping agent that’s required? I would rather not but if it’s the generally accepted method to use it then that may solve some of the issues
Thanks again for everyone’s help,
See if you can find a copy of Audel's Millwrights Handbook as there's a lot of great info in there on setting up and maintaining line-shafts.
One thing to also consider is the angle the belt is running at in relation it it's rotation. The belt is usually only transmitting power on one side, like a rope being pulled from the driven pulley to the driving pulley, while the other side is just returning to the driving pulley. All belts work the same way, but modern V-belts don't show it as well since they're under so much tension and have built-in rubber grip. A little bit of sag is expected and ok if the belt is horizontal or running at an angle, but if the belt is vertical with a small driving pulley bellow, you'll lose more power to slackness. If you've ever watched old flat belt machinery at the fair, they show the principals the best (being so large and over distance).
As far as belt dressing, to my understanding it isn't required, but greatly helps. Think of it like the difference between a new rubbery V-belt and and old slick one. There used to be companies that made it commercially, but it seems to me that most shops/millwrights just mixed their own. Lots of different recipes, but the common ingredients were rosin, tallow, pine tar, asphaltum, pumice, castor oil, steam cylinder oil, and, and lots of other stuff, all in different ratios depending on who's experience you were with. The general idea was that you wanted something tacky, that stayed tacky over time, but also flowed and didn't build up in one spot or drip off of stationary pulleys and belts. I made a batch a couple years ago and it's a fun experience. Most recipes require everything to be heated and mixed, before being "cast" into a solid. A good tip I found somewhere was to use old paper towel or toilet paper tubes as a mold as the paper helped hold everything together, but comes apart safely as you rub it on a belt like a crayon.
My plan on my set-up at home is to use sewn leather belts (polyester thread) for everything going over short distances as I find that they'll stretch less, and use webbing belts for the longer distance belts.
