Socalpat2000
- Sep 22, 2020
I have a Century Repulsion start induction run motor. As best I can tell it's a pre 1939 because it has no letters in the serial number only numbers. Anyway, I had an issue with the brushes lifting. I took it back apart and freed up the centrifugal mechanism and put it back together again. Now when I plug it in it starts up fine, but as soon as the weights lift the brushes it starts to slow down as if isn't running under power anymore. I took it back apart and checked the resistance across the windings and there is no break as there is continuity across them. Any suggestions on how to proceed?
