Froneck
Titanium
- Dec 4, 2010
- McClure, PA 17059
I have just about every size chuck to fit the spindles of my lathes except the 24" Hendey. (Hardly change the 20" 4 jaw on the machine) However I have quite a few different size chucks that will fit the D1-6 spindles of the 12", 14" Hendeys, 14" L&S and 16" P&W lathes. I have been lucky getting quite a few chucks from HGR that were in excellent shape and a few that seemed to be new very cheap! Latest is a 10" 4 jaw by Skinner that seems to be solid steel being as heavy as it is! It too is in great shape no back plate the pins are mounted directly on the chuck though only 4 due to the jaw screw retainer that prevents 6 from being used. Has seen little use but I had to clean what seemed to be old oil covering.
I have it mounted and used WD-40 after removing all the oils. I'm wondering what is the best oil to lube the jaws and screw plus the jaws and scroll of the 3 and 6 jaw chucks. I also have a number of independent/universal combination 3 and 4 jaw chucks. I'm no lover of WD-40 but buy it by the gallon for use as a cutting lubricant requested by my customer.
Looking for something that will allow long storage periods due to the number of chucks I have.
