PA Engineer
- May 19, 2011
- PA
I found this lathe for sale and I am considering buying it. It was Ran 3 years ago, the guy cut the power out of the building, so i couldnt see it run. It has 3 phase motor with some type of rigged converter..couldnt figure it out. Has like 5 chucks, 3 and 4 jaw. Swing is around 16" and the bed is about 6'
First question is should i get it? This is one lathe that i cant find much info about on here. I have found one thread with an identical looking lathe, but not much info. Are they decent? Iam fairly new to this, own an old Hendy lathe but its not in running order. THis also has a steady rest and an attachement off the back that looks like its used for cutting complex shapes and tapers. Not sure on what this is called, but I gather how it works, i assume you make a jig for it to follow.
The spindle felt solid as did the cross feed. Anybody PM me a ballpark value?
Thanks.
Thanks.
