Clausing 5904 Intermediate Pulley breakdown
Likes Likes:  0
Results 1 to 1 of 1
    Jun 2020
    New York
    Default Clausing 5904 Intermediate Pulley breakdown
    I have most of the intermediate pulley assembly taken down. I can't access the (back half) inner section of the pulley. I am at the clutch housing, snap ring off and can't seem to get any farther. How do I pull the housing...or do I? Based on the bottom pulley set up there are probably two set screws holding the front half to the shaft underneath the back (sliding) half of the pulley. Trying to pull it from that side could seriously damage the entire pulley and probably spoil the shaft as well.
    Any help or input would be greatly appreciated. The last photo is of the broken pulley key way slot.
    I have a good 8 1/2 dia. pulley on it's way. I was told to remove the pulley from the front (timing belt) end. Is this the right way?
    Joel
