Just a Sparky
Hot Rolled
- May 2, 2020
- Minnesota
I'd like to pick some brains regarding the proper setup and use of Armstrong style tool holders. These holders incline 20 degrees upwards into the workpiece. This makes tool grinding a bit easier, but I have to wonder if it might contribute to tool chatter if the tip of the cutter is set at the workpiece's horizontal centerline. As the tool bites into the work and down forces are applied to the bit, the 20* incline will tend to flex into the work, will it not?
From this, is it best practice to tilt the rocker base such that the tool bit contacts the workpiece lower, closer to it's 20* arc-tangent until a facing operation is called for? Or does the general rule of setting the tool at the work's horizontal centerline still hold?
Given I have 1" between the top surface of the rocker and my lathe's centers, would it be more ideal to use a 1/2" square bit stacked on top of a 1/2" square spacer for heavier roughing operations? A bigger tool would have the advantage of better heat-sinking and increased rigidity, would it not?
