cutting gears
Page 1 of 7 123 ... LastLast
Results 1 to 20 of 127
Thread: cutting gears
    Dec 2020
    AUSTRALIA
    105
    70
    13
    Red face cutting gears
    hi all i need to make a missing gear for my smith barker and willson lathe project but don't know where to start as i do not have a sample to copy so i need someone to tell me how to go about this. the missing gear mates up to a 2nd gear which is there but that does not help..any clues???
    Jul 2004
    Houston, TX USA
    32,387
    It does help - the teeth have to mate with the one you need to make
    There is an easy way to find out Diametral Pitch (assumes an "Imperial" make)
    Measure outside diameter of the mate that you have - and record that
    Count teeth and add TWO to that count
    Divide the O.D. into the count plus TWO
    Example - 32 teeth, and 2.125" O.D.
    34 / 2.125 = 16 Diametral Pitch - or "DP"
    Now.....how MANY teeth (on the one to be made) is a bit more work if you have no idea
  3. Likes macsonboy liked this post
    Dec 2020
    AUSTRALIA
    105
    70
    13
    Default smith barker and willson lathe
    thank you john it all helps.i will do the sums you suggest which is more than i knew.this is very hard with no sample
    Dec 2020
    AUSTRALIA
    105
    70
    13
    hi again john , out in the shed today i measured the existing gear=6 1/4 inch=6.250and tooth count 38 plus 2 makes40 so far so good.divide outside diameter into tooth count (40)and we have6.4 diametral pitch.i now need to buy a set of diametral cutters and then somehow do the job ..if not for your help it maybe would never happen, cheers for the help.it is appreciated.
    Feb 2008
    lone jack mo
    414
    36
    42
    6.35 DP is 4 Module which is metric gearing. You will still need to determine pressure angle. 14.5 and 20 degree are the most common. You can compare your tooth profile with one online to note the difference.
    Center to center distance between gears will help calculate number of teeth on missing gear.
    Good luck with your project.
    Jul 2004
    Houston, TX USA
    32,387
    If you scroll down here enough, you can see that Kevin is correct
    Gear Diametral Pitch, Module Conversion Table Chart | Gear Diametral Pitch | Circular Pitch | Module - Engineers Edge
    have fun
    Here is a comparison 14 1/2 to 20 PA - one can see the 20 is a bit more "pointy" - with more tooth "beef" at the bottom
  8. Likes macsonboy liked this post
  9. #7
    May 2009
    Canandaigua, NY, USA
    3,412
    178
    1729
    Can't offer much more than above, save for encouragement. The first time you cut a gear it's a bit mysterious and scary. After you've done one or two, it's easy and by the time you reach one or two dozen teeth (by hand with a dividing head) it actually gets boring. That's the point where you don't want to lose concentration and mess up! There are fewer and fewer decently priced involute gear cutters available, but they do exist if you do a good search.
  10. Likes macsonboy liked this post
  11. #8
    Dec 2009
    Dearborn, Michigan
    1,434
    120
    281
    Let's see pictures of the lathe and the gears.
  12. Likes macsonboy liked this post
  13. #9
    Mar 2007
    England UK
    2,001
    824
    845
    Page HERE covering that manufacturer. Must be a hefty machine to have a MOD 4 gear in the train.
  14. Likes macsonboy liked this post
  15. #10
    Jun 2012
    Michigan
    14,240
    4853
    5133
    Just that the Op's title and great information are ideal for a future search of this question and solution.
  16. #11
    Jul 2004
    Houston, TX USA
    32,387
    Probably makes sense to NOT just assume mod 4 gear goes there. Any following mod 4 gears there? Like on end of lead screw? Maybe all the gears were missing and a PO thought the "found" mod 4 was as good as place to start as any in gearing it up. As suggested in a post above, mod 4 is way overkill unless the lathe is a "bigun"
    As a for instance, my 9900 lb 24 X 80" Lodge & Shipley only had 8 DP (mod 3.175) gears back there
  17. Likes DeSelle, kevin johnson liked this post
  18. #12
    Feb 2004
    Baltimore, MD, USA
    4,390
    513
    804
    Quote Originally Posted by Conrad Hoffman View Post
    error on 1 tooth, missed a turn on the rotary table, or one too many...
  19. Likes Matt_Maguire liked this post
  20. #13
    May 2009
    3,412
    178
    1729
    Yeah, sucks when that happens. I throw mine out so nobody saw nuttin! FWIW, I make many gears for my small Logan out of Delrin. They hold up great and are much easier to cut, plus the cutters last forever.
  21. #14
    Feb 2004
    Baltimore, MD, USA
    4,390
    513
    804
    This one 6061, for my father to cut the threads he wants using his SB 9". i wanted to scrap it and start over, but it was a rush job, so we filed the error down a bit and it works ok-ish. gives him something to tease me about when i make fun of how dirty he leaves his lathe 😁
  22. #15
    Jul 2004
    Houston, TX USA
    32,387
    Borrowed from another of your threads......
    Where is the 38 T going?
    What's on this end of lead screw?
    Hard to believe you are running that direct off a cone pulley equipped motor - does it not go way way too fast?
  23. #16
    Apr 2018
    9,220
    4476
    Quote Originally Posted by kevin johnson View Post
    I've never seen a 14.5* metric gear. Not going to say they don't exist, cuz there's probably one (1) somewhere, but definitely not the norm.
  24. #17
    Mar 2001
    Switzerland
    2,778
    3258
    1315
    Quote Originally Posted by EmanuelGoldstein View Post
    I think the Deckel FP 1 machines are 14.5. 20 for all later developed machines FP2 etc.
  25. #18
    Mar 2007
    England UK
    2,001
    824
    845
    I would agree, I've never seen one either yet I do have a 0.5mod 14.5PA hob.
    I would also agree with John about not going on the MOD4 gear assumption without careful checking because Willson lathes are apparently specified in inches in every other way.
  26. #19
    Apr 2018
    9,220
    4476
    Quote Originally Posted by Screwmachine View Post
    That's what makes it dangerous to say "never" ... with gears, someone, somewhere has done it at least once.
    Good to know tho, I'll put that in the 'little-known facts' section of the brain
    4 mod does seem pretty huge for a little thing like that. But you never know who knocked together what to keep the thing running, some time in the past.
  27. #20
    Feb 2004
    peekskill, NY
    27,422
    6388
    Yeah, gears are *easy*, right?
  28. Likes macsonboy, TheOldCar, Asquith liked this post
