Devlieg (Herbert) 2b36 drawbar
pressbrake1
Stainless
Dec 8, 2012
essex england
Hello. I finally moved my devlieg inside after several months.
On inspection the drawback has a striped thread or snapped off as I believe it had been converted to metric to use bt tooling.
Has anyone done one and is it a complete expensive pita.
I’m not adverse to just having a manual drawbar for the amount of changes I’d be doing.
Unfortunately price of scrap is zero and I spent too much money moving it etc etc
My understanding is it's not to big of job. You unbolt/split the drawbar and motor assembly from the head and slide the motor back on the rails to access the drawbar.
Do you have books? I have USA books, I doubt if Herbert is significantly different.
These directions are from a K series.
Attaching some cartoons of 2,3 & 4B spindles & drawbar. I removed one once that had been welded & re-threaded and have no idea how long it lasted but I had used it that way for a couple of years before it went tits-up.
Good luck,
Matt
They usually last a long time like that, as long as you clean the taper out it's going to probably last a solid 10 or 20 years
