Greg Menke
- Feb 22, 2004
- Baltimore, MD, USA
Probably used on lots of other machines too. Anyway I've been carefully avoiding listening to the noisy bearing in the motor but it got bad enough to finally take notice. I have it apart as below but no sign of how to get it apart further without drilling out the impeller shaft which seems too destructive. The top bearing turns OK by hand, not obviously bad- sealed type and the grease is really stiff.
I note two little diagonal holes at the joint between stem and base, leading to the shaft- one is shown here. I can see the shaft rotate in there, but no sign of anything to unscrew or drive out. I keep wanting something to be in there which would separate the motor shaft from the impeller shaft but maybe not?
The lower motor bearing is still in place, the last step before stopping here was prying the end bell forward which pulled the bearing free from it.
Many thanks!
Greg
Many thanks!
Greg
